joe Guest
compiler version? |
Posted: Wed Jun 29, 2005 10:45 pm |
i cant compile using my mplab v6.3 for PIC12F683. i believe should be the compiler version as it works ok for PIC12F629.
my ccsc.exe version is 3.5.0.91
Do anyone know whats the problem? How do i check the compiler version properties? |
joe Guest
Posted: Wed Jun 29, 2005 10:46 pm |
just to add on...
i try to search for 12F683.h and it was not even in my device folder.. |
Posted: Wed Jun 29, 2005 10:55 pm |
There are at least three ways to find the compiler version.
1. Compile a test file, and look at the top of the .LST file.
It will show the version.
2. Click on Start/Programs, and then find the entry for CCS.
It might be called "PIC-C". Then click on the icon for "Compiler Version".
2. Open a DOS window and go to c:\Program Files\Picc
and run this command line: CCSC +v
The version will be a number in this format: 2.734, or 3.191, or 3.226, etc. |
joe Guest
Posted: Thu Jun 30, 2005 12:13 am |
thanks for the info..
my pcb ver 3.173
pcm ver 3.173
so what do i need to do to be able to compile PIC12F638?
thanks |
Posted: Thu Jun 30, 2005 12:26 am |
Your version of the compiler doesn't support the 12F683.
Probably the best thing is to upgrade the compiler. |
joe Guest
Posted: Thu Jun 30, 2005 1:29 am |
So the only thing that i can do is to upgrade to the current one..?
Is there any other way out, cos i only need to compile that chip and no extra features needed. |
joe Guest
Posted: Thu Jun 30, 2005 1:33 am |
I dun really want to spend the $99 on the one year upgrade...hmmm. |
Mark
Posted: Thu Jun 30, 2005 5:04 pm |
Then you dun really want to compile the code then! Don't want to spend the money, then write in asm or use another pic. |
dyeatman
Posted: Thu Jun 30, 2005 5:24 pm |
Deleted...
Posted: Thu Jun 30, 2005 5:45 pm |
The 12F683 is twice as capable as the 12F675/12F629,
so I'm sure that's why he wanted to use it. But his
version of the compiler doesn't support it.
Here is a short summary of the differences:
Feature PIC12F675 PIC12F683
Max Prog. Mem. 1024 2048
SRAM 64 128
Data EEPROM 128 256
Timers (8/16) 1/1 2/1
CCP N Y
Int Osc freq 4 MHz 32 KHz - 8 MHz
Clock switching N Y
joe Guest
Posted: Thu Jun 30, 2005 7:13 pm |
Thanks for the reply..
i need the improved 629 .. thus i went for a 683... becos i am quite new to firmware programming and so on.. i immediately placed an order for 683 to realise that i cant compile it on my usual version..
so i guess [wallet-$99].
Thanks anyway for the replies especially PCM programmer..  |
joe Guest
Posted: Thu Jun 30, 2005 7:14 pm |
C-H Wu Guest
F629/F675 to F683 migration |
Posted: Thu Jun 30, 2005 10:01 pm |
PCM programmer wrote: | The 12F683 is twice as capable as the 12F675/12F629,
SRAM 64 128
Data EEPROM 128 256
CCP N Y
Clock switching N Y
PCWH -> Tools -> Device Editor -> 12F675
Can't we use Device Editor to create a new chip ?
and/or just copy/edit the device header C:\Program Files\PICC\Devices\12F675.h to make our own 12F683.h
or just modify the 12F675.h along with Device Editor
I don't think $99 is a necessary unless 3.173 has bug with F675.
Best wishes
C-H Wu |
Posted: Thu Jun 30, 2005 11:57 pm |
He mentioned his versions of PCB and PCM, and he said he uses MPLAB to
compile. He also said the upgrade was $99, which is the price for the
PCM maintenance. So I assumed that he doesn't have PCW or PCWH.
You only get the Device Editor with those products. You don't get it
with just plain PCM or PCH. |
Posted: Sat Jul 02, 2005 10:44 am |
PCM programmer wrote: | He mentioned his versions of PCB and PCM, and he said he uses MPLAB to
OOOPs, you are right !  |
