compiler version?
Goto page 1, 2  Next
joe
compiler version?
PostPosted: Wed Jun 29, 2005 10:45 pm     Reply with quote
i cant compile using my mplab v6.3 for PIC12F683. i believe should be the compiler version as it works ok for PIC12F629.
my ccsc.exe version is 3.5.0.91
Do anyone know whats the problem? How do i check the compiler version properties?
joe
PostPosted: Wed Jun 29, 2005 10:46 pm     Reply with quote
just to add on...
i try to search for 12F683.h and it was not even in my device folder..
PostPosted: Wed Jun 29, 2005 10:55 pm     Reply with quote
There are at least three ways to find the compiler version.
1. Compile a test file, and look at the top of the .LST file.
It will show the version.
2. Click on Start/Programs, and then find the entry for CCS.
It might be called "PIC-C". Then click on the icon for "Compiler Version".
2. Open a DOS window and go to c:\Program Files\Picc
and run this command line: CCSC +v
The version will be a number in this format: 2.734, or 3.191, or 3.226, etc.
joe
PostPosted: Thu Jun 30, 2005 12:13 am     Reply with quote
thanks for the info..
my pcb ver 3.173
pcm ver 3.173
so what do i need to do to be able to compile PIC12F638?
thanks
PostPosted: Thu Jun 30, 2005 12:26 am     Reply with quote
Your version of the compiler doesn't support the 12F683.
Probably the best thing is to upgrade the compiler.
joe
PostPosted: Thu Jun 30, 2005 1:29 am     Reply with quote
So the only thing that i can do is to upgrade to the current one..?
Is there any other way out, cos i only need to compile that chip and no extra features needed.
joe
PostPosted: Thu Jun 30, 2005 1:33 am     Reply with quote
I dun really want to spend the $99 on the one year upgrade...hmmm.
Mark
PostPosted: Thu Jun 30, 2005 5:04 pm     Reply with quote
Then you dun really want to compile the code then! Don't want to spend the money, then write in asm or use another pic.
dyeatman
PostPosted: Thu Jun 30, 2005 5:24 pm     Reply with quote
Deleted...
PostPosted: Thu Jun 30, 2005 5:45 pm     Reply with quote
The 12F683 is twice as capable as the 12F675/12F629,
so I'm sure that's why he wanted to use it. But his
version of the compiler doesn't support it.
Here is a short summary of the differences:
Feature         PIC12F675      PIC12F683
Max Prog. Mem.   1024          2048
SRAM             64            128
Data EEPROM      128           256
Timers (8/16)    1/1           2/1
CCP              N             Y
Int Osc freq     4 MHz         32 KHz - 8 MHz
Clock switching  N             Y
joe
PostPosted: Thu Jun 30, 2005 7:13 pm     Reply with quote
Thanks for the reply..
i need the improved 629 .. thus i went for a 683... becos i am quite new to firmware programming and so on.. i immediately placed an order for 683 to realise that i cant compile it on my usual version..
so i guess [wallet-$99].
Thanks anyway for the replies especially PCM programmer.. Smile
joe
PostPosted: Thu Jun 30, 2005 7:14 pm     Reply with quote
C-H Wu
F629/F675 to F683 migration
PostPosted: Thu Jun 30, 2005 10:01 pm     Reply with quote
SRAM             64            128
Data EEPROM      128           256
CCP              N             Y
Clock switching  N             Y
PCWH -> Tools -> Device Editor -> 12F675
Can't we use Device Editor to create a new chip ? Confused
and/or just copy/edit the device header C:\Program Files\PICC\Devices\12F675.h to make our own 12F683.h
or just modify the 12F675.h along with Device Editor
I don't think $99 is a necessary unless 3.173 has bug with F675.
Best wishes
C-H Wu
PostPosted: Thu Jun 30, 2005 11:57 pm     Reply with quote
He mentioned his versions of PCB and PCM, and he said he uses MPLAB to
compile. He also said the upgrade was $99, which is the price for the
PCM maintenance. So I assumed that he doesn't have PCW or PCWH.
You only get the Device Editor with those products. You don't get it
with just plain PCM or PCH.
PostPosted: Sat Jul 02, 2005 10:44 am     Reply with quote
OOOPs, you are right ! Embarassed
Goto page 1, 2  Next
Page 1 of 2
