I'm using a 16F818 for my latest project and all works fine on a 5V supply.
I have now been asked if this could work on a lower supply rail 3.3v
I looked at the data sheet fig 15.2 and at the frequency I'm using it at (4MHz) I thought yep should work down to 2V according to datasheet, so i swapped my 78L05 for a 78L33 (3.3V equivalent) but to my suprise it doesn't work at all not a thing
So I looked back at the Datasheet and saw Fig 15.1 that shows 4V as the minimum voltage for a extended/industrial. I bought these as the Industrial version and are marked 16F818 - I/P are these the Industrial part or the Extended / Industrial as this is the only explanation I can see or is there something else i'm missing?
thanks
JFK
Chas Guest
Posted: Wed May 04, 2005 10:52 am
Check the part number closely. It is the PIC16LF818 that runs down to 2.0 V. The PIC16F818 is limited to 4.0V min. The PIC16LF818 is a dropin replacement that is just guaranteed to a lower voltage with some limitations, mostly in operating frequency.
Posted: Wed May 04, 2005 11:43 am
In addition to the F vs. LF issue, one other common reason for
failure to operate at a lower voltage is that Brownout reset is enabled.
Many PICs don't have a selectable Brownout voltage. It's permanently
set at about 4v. These PICs can only use Brownout if they are running at 5v.
JohnKennedy
Posted: Thu May 05, 2005 2:28 am
thanks guys I'll check that
JFK
vizitibi Guest
16f818
Posted: Sun May 15, 2005 1:27 am
with my students we use this chip with internal osc at 8MHz, and this chip works correctly from 2.2V
the brown out detect must be off
config number is 3f10
