Minimum supply Voltage for a 16F818?
JohnKennedy
PostPosted: Wed May 04, 2005 8:48 am     Reply with quote
Hi all
I'm using a 16F818 for my latest project and all works fine on a 5V supply.
I have now been asked if this could work on a lower supply rail 3.3v
I looked at the data sheet fig 15.2 and at the frequency I'm using it at (4MHz) I thought yep should work down to 2V according to datasheet, so i swapped my 78L05 for a 78L33 (3.3V equivalent) but to my suprise it doesn't work at all not a thing Confused
So I looked back at the Datasheet and saw Fig 15.1 that shows 4V as the minimum voltage for a extended/industrial. I bought these as the Industrial version and are marked 16F818 - I/P are these the Industrial part or the Extended / Industrial as this is the only explanation I can see or is there something else i'm missing?
thanks
JFK
Chas
PostPosted: Wed May 04, 2005 10:52 am     Reply with quote
Check the part number closely. It is the PIC16LF818 that runs down to 2.0 V. The PIC16F818 is limited to 4.0V min. The PIC16LF818 is a dropin replacement that is just guaranteed to a lower voltage with some limitations, mostly in operating frequency.
PostPosted: Wed May 04, 2005 11:43 am     Reply with quote
In addition to the F vs. LF issue, one other common reason for
failure to operate at a lower voltage is that Brownout reset is enabled.
Many PICs don't have a selectable Brownout voltage. It's permanently
set at about 4v. These PICs can only use Brownout if they are running at 5v.
JohnKennedy
PostPosted: Thu May 05, 2005 2:28 am     Reply with quote
thanks guys I'll check that
JFK
vizitibi
16f818
PostPosted: Sun May 15, 2005 1:27 am     Reply with quote
with my students we use this chip with internal osc at 8MHz, and this chip works correctly from 2.2V
the brown out detect must be off
config number is 3f10
sorry my wrong english....
tibor
