MOVLF xC5 putting to wrong xC5
object01
PostPosted: Tue May 10, 2005 4:49 pm     Reply with quote
This line,
parserState = opcode;
compiles to
3D64:  MOVLW  04
3D66:  MOVWF  xC5
(opcode is the 5th member of an enum)
The symbol map shows parserState at location 0x0C5. But instead, 0x6C5 is getting assigned the value 4. I can't imagine that this is anything other than a compiler bug, but I don't know how to go about working around it. Truthfully, I don't know enough about indirect addressing to be able to spot the problem.
Any suggestions?
Jeff S.
object01
PostPosted: Tue May 10, 2005 4:57 pm     Reply with quote
(ok, so I got the subject line wrong...)
PostPosted: Tue May 10, 2005 5:00 pm     Reply with quote
Post a program that we can compile. Post your compiler version.
object01
PostPosted: Tue May 10, 2005 5:02 pm     Reply with quote
I knew you were gonna say that.
I can't reproduce the problem yet using anything other than the ginormous program in question. If I trim it down the problem goes away. My compiler version is 3.223. I'll try reproducing it in something postable.
Jeff S.
object01
PostPosted: Tue May 10, 2005 7:48 pm     Reply with quote
It's still tough to get this into a smaller, compilable program, but I found a workaround. The variables stopPoint and i are both unsigned int8.
Here's the listing of the erroneous section:
....................                      // This line caused a compiler bug in PIC-C version 3.223.
....................                      // The line below, parserState = opcode, was setting the
....................                      // incorrect location in RAM due to a missing MOVLB instruction.
....................                      // The compiler moved one value into the BSR to perform this line,
....................                      // then didn't reset it to the proper value afterwards.
....................                      // Splitting this statement into two lines made the compiler
....................                      // execute another MOVLB instruction before the
....................                      // parserState = opcode line.
....................                      stopPoint = strlen(&(tdif->buffer[i])) + i;
383E:  CLRF   03
3840:  MOVF   xCA,W
3842:  ADDLW  7C
3844:  MOVWF  01
3846:  MOVLW  00
3848:  ADDWFC 03,F
384A:  MOVF   01,W
384C:  MOVLB  5
384E:  ADDWF  xA4,W
3850:  MOVLB  6
3852:  MOVWF  xA8
3854:  MOVLB  5
3856:  MOVF   xA5,W
3858:  ADDWFC 03,W
385A:  MOVLB  6
385C:  MOVWF  xA9
385E:  MOVWF  xAC
3860:  MOVFF  6A8,6AB
3864:  MOVLB  0
3866:  CALL   2D28
386A:  MOVFF  01,6A9
386E:  MOVF   xCA,W
3870:  MOVLB  6
3872:  ADDWF  01,W
3874:  MOVWF  01
3876:  MOVLW  00
3878:  ADDWFC 02,W
387A:  MOVFF  01,CB
....................                      //stopPoint = strlen(&(tdif->buffer[i]));
....................                      //stopPoint += i;
....................                      // Output one delimiter on next call
....................                      outputDelimiter = TRUE;
387E:  BSF    20.1
....................                      parserState = opcode;
3880:  MOVLW  04
3882:  MOVWF  xC5
And here's the workaround. Breaking apart the stopPoint statement seemed to reintroduce the necessary MOVLB instruction.
....................                      //stopPoint = strlen(&(tdif->buffer[i])) + i;
....................                      stopPoint = strlen(&(tdif->buffer[i]));
383C:  CLRF   03
383E:  MOVF   xCA,W
3840:  ADDLW  7C
3842:  MOVWF  01
3844:  MOVLW  00
3846:  ADDWFC 03,F
3848:  MOVF   01,W
384A:  MOVLB  5
384C:  ADDWF  xA4,W
384E:  MOVLB  6
3850:  MOVWF  xA8
3852:  MOVLB  5
3854:  MOVF   xA5,W
3856:  ADDWFC 03,W
3858:  MOVLB  6
385A:  MOVWF  xA9
385C:  MOVWF  xAC
385E:  MOVFF  6A8,6AB
3862:  MOVLB  0
3864:  CALL   2D28
3868:  MOVFF  01,CB
....................                      stopPoint += i;
386C:  MOVF   xCA,W
386E:  ADDWF  xCB,F
3870:  BSF    20.1
3872:  MOVLW  04
3874:  MOVWF  xC5
Hopefully this might lend some insight into the problem. I'm gonna continue to try and get something more concise and compilable, now that I know what's causing the problem. However, it's important to note that this code used to work. Only after recently making a set of changes to separate source files in the project did it exhibit this problem.
Jeff S.
