object01
Joined: 13 May 2004 Posts: 90 Location: Nashville, TN
MOVLF xC5 putting to wrong xC5 |
Posted: Tue May 10, 2005 4:49 pm |
This line, Code: | parserState = opcode; | compiles to Code: | 3D64: MOVLW 04
3D66: MOVWF xC5 | .
(opcode is the 5th member of an enum)
The symbol map shows parserState at location 0x0C5. But instead, 0x6C5 is getting assigned the value 4. I can't imagine that this is anything other than a compiler bug, but I don't know how to go about working around it. Truthfully, I don't know enough about indirect addressing to be able to spot the problem.
Any suggestions?
Jeff S. |
object01
Posted: Tue May 10, 2005 4:57 pm |
(ok, so I got the subject line wrong...) |
Posted: Tue May 10, 2005 5:00 pm |
Post a program that we can compile. Post your compiler version. |
object01
Posted: Tue May 10, 2005 5:02 pm |
PCM programmer wrote: | Post a program that we can compile. Post your compiler version. |
I knew you were gonna say that.
I can't reproduce the problem yet using anything other than the ginormous program in question. If I trim it down the problem goes away. My compiler version is 3.223. I'll try reproducing it in something postable.
Jeff S. |
object01
Posted: Tue May 10, 2005 7:48 pm |
It's still tough to get this into a smaller, compilable program, but I found a workaround. The variables stopPoint and i are both unsigned int8.
Here's the listing of the erroneous section:
Code: | .................... // This line caused a compiler bug in PIC-C version 3.223.
.................... // The line below, parserState = opcode, was setting the
.................... // incorrect location in RAM due to a missing MOVLB instruction.
.................... // The compiler moved one value into the BSR to perform this line,
.................... // then didn't reset it to the proper value afterwards.
.................... // Splitting this statement into two lines made the compiler
.................... // execute another MOVLB instruction before the
.................... // parserState = opcode line.
.................... stopPoint = strlen(&(tdif->buffer[i])) + i;
383E: CLRF 03
3840: MOVF xCA,W
3842: ADDLW 7C
3844: MOVWF 01
3846: MOVLW 00
3848: ADDWFC 03,F
384A: MOVF 01,W
384C: MOVLB 5
384E: ADDWF xA4,W
3850: MOVLB 6
3852: MOVWF xA8
3854: MOVLB 5
3856: MOVF xA5,W
3858: ADDWFC 03,W
385A: MOVLB 6
385C: MOVWF xA9
385E: MOVWF xAC
3860: MOVFF 6A8,6AB
3864: MOVLB 0
3866: CALL 2D28
386A: MOVFF 01,6A9
386E: MOVF xCA,W
3870: MOVLB 6
3872: ADDWF 01,W
3874: MOVWF 01
3876: MOVLW 00
3878: ADDWFC 02,W
387A: MOVFF 01,CB
.................... //stopPoint = strlen(&(tdif->buffer[i]));
.................... //stopPoint += i;
.................... // Output one delimiter on next call
.................... outputDelimiter = TRUE;
387E: BSF 20.1
.................... parserState = opcode;
3880: MOVLW 04
3882: MOVWF xC5 |
And here's the workaround. Breaking apart the stopPoint statement seemed to reintroduce the necessary MOVLB instruction.
.................... //stopPoint = strlen(&(tdif->buffer[i])) + i;
.................... stopPoint = strlen(&(tdif->buffer[i]));
383C: CLRF 03
383E: MOVF xCA,W
3840: ADDLW 7C
3842: MOVWF 01
3844: MOVLW 00
3846: ADDWFC 03,F
3848: MOVF 01,W
384A: MOVLB 5
384C: ADDWF xA4,W
384E: MOVLB 6
3850: MOVWF xA8
3852: MOVLB 5
3854: MOVF xA5,W
3856: ADDWFC 03,W
3858: MOVLB 6
385A: MOVWF xA9
385C: MOVWF xAC
385E: MOVFF 6A8,6AB
3862: MOVLB 0
3864: CALL 2D28
3868: MOVFF 01,CB
.................... stopPoint += i;
386C: MOVF xCA,W
386E: ADDWF xCB,F
3870: BSF 20.1
3872: MOVLW 04
3874: MOVWF xC5 |
Hopefully this might lend some insight into the problem. I'm gonna continue to try and get something more concise and compilable, now that I know what's causing the problem. However, it's important to note that this code used to work. Only after recently making a set of changes to separate source files in the project did it exhibit this problem.
Jeff S. |
