Only the last I/O line (PIN_A1) works! I tryed to drive one line per time and all is ok so the lines work. The result will be a square wave on each line.
All work fine but 1ms between lines is too long for my application. What is the problem? Is a bug or each line takes some time for commutation?
Best regards.
Posted: Fri May 06, 2005 2:46 pm
This is probably caused by the classic Read-Modify-Write problem.
The solution is to maintain a "shadow" register (a byte variable) in RAM
for all of your Port A pins. When you want to change the value of a
pin, you should change it in the Shadow register. Then write the
entire shadow register value to Port A in one operation. Don't do
individual bit set and clear operations.
Also, I'm assuming that you did everything else correctly on the 16F628,
such as disabling the comparators.
firefox78
Posted: Sat May 07, 2005 3:40 am
Tank you very much. I will try your solution next week.
Best regards
fuzzy
Posted: Sat May 07, 2005 4:15 pm
I had simlar problem with PIC16F876.
Port A is analog in this MCU so I had to specify, (NO_ANALOG) in ADC setup to have a digital Port. I don't know wether in your pic PORT a is analog .
