I/O commutation time or bug ?
firefox78
PostPosted: Fri May 06, 2005 2:08 pm     Reply with quote
I try to drive 2 ingectors at the same time with a PIC16F628 but with the follow code I have a big problem
output_low(PIN_A0);
output_low(PIN_A1);
delay_ms(15);
output_high(PIN_A0);
output_high(PIN_A1);
delay_ms(15);
Only the last I/O line (PIN_A1) works! I tryed to drive one line per time and all is ok so the lines work. The result will be a square wave on each line.
If I use the follow code
output_low(PIN_A0);
delay_ms(1);
output_low(PIN_A1);
delay_ms(15);
delay_ms(1);
delay_ms(15);
All work fine but 1ms between lines is too long for my application. What is the problem? Is a bug or each line takes some time for commutation?
Best regards.
PostPosted: Fri May 06, 2005 2:46 pm     Reply with quote
This is probably caused by the classic Read-Modify-Write problem.
The solution is to maintain a "shadow" register (a byte variable) in RAM
for all of your Port A pins. When you want to change the value of a
pin, you should change it in the Shadow register. Then write the
entire shadow register value to Port A in one operation. Don't do
individual bit set and clear operations.
See my large post in this thread. It has sample code which shows
how to implement a shadow register for Port A.
http://www.ccsinfo.com/forum/viewtopic.php?t=21825&start=15
Also, I'm assuming that you did everything else correctly on the 16F628,
such as disabling the comparators.
firefox78
PostPosted: Sat May 07, 2005 3:40 am     Reply with quote
Tank you very much. I will try your solution next week.
Best regards
fuzzy
PostPosted: Sat May 07, 2005 4:15 pm     Reply with quote
I had simlar problem with PIC16F876.
Port A is analog in this MCU so I had to specify, (NO_ANALOG) in ADC setup to have a digital Port. I don't know wether in your pic PORT a is analog .
