Work debugging and without not
bertronicom
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Mon Apr 25, 2005 5:35 am     Reply with quote
CCS v3.223
ICD v2.29
I have working my program with debug but when I program with ICD the pic don't work.
#fuses NOWDT,WDT128,XT, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, NODEBUG, LVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
//#device ICD=true
PostPosted: Mon Apr 25, 2005 6:56 am     Reply with quote
Can you post your fuse line for debugging.
drolleman
PostPosted: Mon Apr 25, 2005 7:44 am     Reply with quote
Make sure you set the the debuging off and dont program with debug but program mode.
Mark
PostPosted: Mon Apr 25, 2005 10:31 am     Reply with quote
And remember to remove the programming/debugging header. It might be keeping the device in reset. There is a button on the programming toolbar in MPLAB to release from reset if you don't want to disconnect the programming header.
treitmey
PostPosted: Mon Apr 25, 2005 11:21 am     Reply with quote
And remember if your doing serial com to you PC. You may need a ground wire connecting the two. If you don't have a common reference, serial comm might not work well. You see with the ICD in place, it is providing that common gound. When you remove ICD the serial comm stops working.
