Andrewv
Interrupts kill program |
Posted: Wed Apr 20, 2005 4:41 pm |
Hi.
I've been having huge problems the last few days trying to get my timer interrupts working. I have taken almost everything out of my code and it still doesn't work.
I am trying to get an interrupt on timer2 every 5 ms. I am using a PIC 18F6680. With a 10 Mhz clock. Using the Phase lock loop for a clock speed of 40 Mhz.
My problem is that when I enable interrupts my outputs go dead and the board doesn't seem to do anything.
Here is my code
#include <18f6680.h>
#device ADC=10
#fuses H4,NOWDT,WDT128,NOPROTECT,NOLVP,CCP2C1,BROWNOUT,BORV45,PUT
#use delay(clock=40000000)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#use fast_io(F)
#use fast_io(G)
/* Initialize the I/O direction registers */
void initialize_IO_direction(void)
SET_TRIS_A(0b11111111);
SET_TRIS_B(0b11111111);
SET_TRIS_C(0b00000000);
SET_TRIS_D(0b11111111);
SET_TRIS_E(0b11111001);
SET_TRIS_F(0b11111110);
SET_TRIS_G(0b11111110);
/* Timer 2 Overflow, general purpose timing, gontrol action timeout */
#int_TIMER2
void control_timer_isr()
output_high(PIN_C0);
counter++;
if (stdDemandDebounce) stdDemandDebounce--;
if (enableCompDebounce) enableCompDebounce--;
if (dualRunDebounce) dualRunDebounce--;
if (compSelDebounce) compSelDebounce--;
if (blinkTimer) blinkTimer--;
if (compUnlTimer) compUnlTimer--;
} // int_timer2
/* Main routine. Called at power up and reset */
#zero_ram
//double
setup_wdt(WDT_OFF);
//Initialize timer 2 for general timing with a 5ms overflow
setup_timer_2(T2_DIV_BY_16, 222, 14); //5ms overflows
//Enable overflow interrupts on timer 2 (every 5ms).
disable_interrupts(INT_RTCC);
disable_interrupts(INT_TIMER0);
disable_interrupts(INT_TIMER1);
disable_interrupts(INT_TIMER3);
disable_interrupts(INT_EXT);
disable_interrupts(INT_EXT1);
disable_interrupts(INT_EXT2);
disable_interrupts(INT_EXT3);
disable_interrupts(INT_RB);
disable_interrupts(INT_PSP);
disable_interrupts(INT_AD);
disable_interrupts(INT_RDA);
disable_interrupts(INT_TBE);
disable_interrupts(INT_SSP);// 0x9D08
disable_interrupts(INT_CCP1);// 0x9D04
disable_interrupts(INT_CCP2);// 0xA001
disable_interrupts(INT_BUSCOL);// 0xA008
disable_interrupts(INT_LOWVOLT);// 0xA004
disable_interrupts(INT_CANIRX);// 0xA380
disable_interrupts(INT_CANWAKE);// 0xA340
disable_interrupts(INT_CANERR);// 0xA320
disable_interrupts(INT_COMP);// 0xA040
disable_interrupts(INT_EEPROM);// 0xA010
disable_interrupts(INT_CANTX2);// 0xA310
disable_interrupts(INT_CANTX1);// 0xA308
disable_interrupts(INT_CANTX0);// 0xA304
disable_interrupts(INT_CANRX1);// 0xA302
disable_interrupts(INT_CANRX0);// 0xA301
disable_interrupts(INT_LVD);// 0xA004
bit_clear(*RCSTA, 7); //disable the serial port as we are using C6 for I/O
initialize_IO_direction();
// delay_ms(100);
// set_timer2(0);
output_c(0);
do //Main program loop
//restart_wdt();
output_high(PIN_C7);
output_low(PIN_C7);
If I remove the enable_interrupts(global); line then the LED I have picked up to pic_c7 blinks. If I have enable_interrupts(GLOBAL) on then nothing happens and the LED I have hooked up to PIN_C0 does not go on.
I'm sure I am not doing something really really simple but can't figure it out.
Thanks for your help,
Andrew Valeri |
Posted: Wed Apr 20, 2005 5:08 pm |
Quote: | I have taken almost everything out of my code and it still doesn't work. |
The program that you posted is not a simple test program.
If you want to test Timer2 interrupts, then you can remove
about 95% of your program.
Look at my post in the following thread. It has a small test program
which is designed to only test Timer2 interrupts. It doesn't do anything
else. You should try to make a test program similar to this.
http://www.ccsinfo.com/forum/viewtopic.php?t=22447 |
Humberto
Posted: Thu Apr 21, 2005 7:22 am |
Andrewv wrote:
//restart_wdt();
output_low(PIN_C7);
do statement is not a loop, it execute only once
To get a loop it needs to test a while(TRUE) at the end.
//restart_wdt();
output_low(PIN_C7);
}while(1);
Humberto |
