Interrupts kill program
Andrewv
PostPosted: Wed Apr 20, 2005 4:41 pm     Reply with quote
Hi.
I've been having huge problems the last few days trying to get my timer interrupts working. I have taken almost everything out of my code and it still doesn't work.
I am trying to get an interrupt on timer2 every 5 ms. I am using a PIC 18F6680. With a 10 Mhz clock. Using the Phase lock loop for a clock speed of 40 Mhz.
My problem is that when I enable interrupts my outputs go dead and the board doesn't seem to do anything.
Here is my code
#include <18f6680.h>
#device ADC=10
#fuses H4,NOWDT,WDT128,NOPROTECT,NOLVP,CCP2C1,BROWNOUT,BORV45,PUT
#use delay(clock=40000000)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#use fast_io(F)
#use fast_io(G)
/* Initialize the I/O direction registers                                 */
void initialize_IO_direction(void)
   SET_TRIS_A(0b11111111);
   SET_TRIS_B(0b11111111);
   SET_TRIS_C(0b00000000);
   SET_TRIS_D(0b11111111);
   SET_TRIS_E(0b11111001);
   SET_TRIS_F(0b11111110);
   SET_TRIS_G(0b11111110);
/* Timer 2 Overflow, general purpose timing, gontrol action timeout       */
#int_TIMER2
void control_timer_isr()
   output_high(PIN_C0);
   counter++;
   if (stdDemandDebounce)   stdDemandDebounce--;
   if (enableCompDebounce)  enableCompDebounce--;
   if (dualRunDebounce)      dualRunDebounce--;
   if (compSelDebounce)      compSelDebounce--;
   if (blinkTimer)          blinkTimer--;
   if (compUnlTimer)        compUnlTimer--;
} // int_timer2
/* Main routine.  Called at power up and reset                               */
#zero_ram
//double
      setup_wdt(WDT_OFF);
      //Initialize timer 2 for general timing with a 5ms overflow
       setup_timer_2(T2_DIV_BY_16, 222, 14);      //5ms overflows
      //Enable overflow interrupts on timer 2 (every 5ms).
      disable_interrupts(INT_RTCC);
      disable_interrupts(INT_TIMER0);
      disable_interrupts(INT_TIMER1);
        disable_interrupts(INT_TIMER3);
        disable_interrupts(INT_EXT);
disable_interrupts(INT_EXT1);
disable_interrupts(INT_EXT2);
disable_interrupts(INT_EXT3);
disable_interrupts(INT_RB);
disable_interrupts(INT_PSP);
disable_interrupts(INT_AD);
disable_interrupts(INT_RDA);
disable_interrupts(INT_TBE);
disable_interrupts(INT_SSP);//                   0x9D08
disable_interrupts(INT_CCP1);//                  0x9D04
disable_interrupts(INT_CCP2);//                  0xA001
disable_interrupts(INT_BUSCOL);//                0xA008
disable_interrupts(INT_LOWVOLT);//               0xA004
disable_interrupts(INT_CANIRX);//                0xA380
disable_interrupts(INT_CANWAKE);//               0xA340
disable_interrupts(INT_CANERR);//                0xA320
disable_interrupts(INT_COMP);//                  0xA040
disable_interrupts(INT_EEPROM);//                0xA010
disable_interrupts(INT_CANTX2);//                0xA310
disable_interrupts(INT_CANTX1);//                0xA308
disable_interrupts(INT_CANTX0);//                0xA304
disable_interrupts(INT_CANRX1);//                0xA302
disable_interrupts(INT_CANRX0);//   0xA301
disable_interrupts(INT_LVD);//                   0xA004
      bit_clear(*RCSTA, 7);   //disable the serial port as we are using C6 for I/O
      initialize_IO_direction();
//      delay_ms(100);
//     set_timer2(0);
     output_c(0);
do //Main program loop
        //restart_wdt();
        output_high(PIN_C7);
        output_low(PIN_C7);
If I remove the enable_interrupts(global); line then the LED I have picked up to pic_c7 blinks. If I have enable_interrupts(GLOBAL) on then nothing happens and the LED I have hooked up to PIN_C0 does not go on.
I'm sure I am not doing something really really simple but can't figure it out.
Thanks for your help,
Andrew Valeri
PostPosted: Wed Apr 20, 2005 5:08 pm     Reply with quote
The program that you posted is not a simple test program.
If you want to test Timer2 interrupts, then you can remove
about 95% of your program.
Look at my post in the following thread. It has a small test program
which is designed to only test Timer2 interrupts. It doesn't do anything
else. You should try to make a test program similar to this.
http://www.ccsinfo.com/forum/viewtopic.php?t=22447
Humberto
PostPosted: Thu Apr 21, 2005 7:22 am     Reply with quote
  //restart_wdt();
   output_low(PIN_C7);
do statement is not a loop, it execute only once
To get a loop it needs to test a while(TRUE) at the end.
   //restart_wdt();
   output_low(PIN_C7);
  }while(1);
Humberto
