f877 port D input problem
minemind
PostPosted: Mon Apr 11, 2005 9:09 pm     Reply with quote
I'm having problem reading from port d. Port d use 10k pullups resistor and port a have led on each pins.
Am i missing something? I cannot read from port d. i'm using ccs ver2.686.
please help me since i've been working around for about quite some time. Below are some of the code.
#fuses HS, NOWDT, PUT, NOBROWNOUT, NOLVP, NOPROTECT
#USE FAST_IO(D)
#USE FAST_IO(E)
#byte portd=8
#byte porte=9
void main() {
char dBuff;
// i disable all interrupts
// and then. . .
disable_interrupts(GLOBAL);
port_b_pullups(FALSE); // disable pullups
setup_adc_ports(NO_ANALOGS); // disable analogs.
setup_psp(PSP_DISABLED); // disable psp
set_tris_d(0xff);
while (1) {
porta=portd; // send to porta, and this not working
dBuff=portd;
printf("%c", dBuff);
minemind
Sugiman
PostPosted: Tue Apr 12, 2005 2:29 am     Reply with quote
set_tris_d(0xff);
Did you also set up port A for output somewhere in your code?
treitmey
try this
PostPosted: Tue Apr 12, 2005 8:01 am     Reply with quote
#include <16F877.h>
#device *=16
#fuses HS,NOWDT,NOLVP,PROTECT,PUT,BROWNOUT
#use rs232(baud=9600,xmit=PIN_C4,INVERT,stream=DEBUG) // STDERR(same as DEBUG)
#use rs232(baud=1200,errors,xmit=PIN_C6,rcv=PIN_C7,parity=e,enable=PIN_C5,bits=8,stream=CIM)
#case
#zero_ram
#define VER_MAJOR 1
#define VER_MINOR 01
#use fast_io(D)
#byte relays=8 //16F877 port D is at 8
#USE FAST_IO(A)
#USE FAST_IO(B)
#USE FAST_IO(C)
#USE FAST_IO(D)
#USE FAST_IO(E)
#byte porta=5
#byte portb=6
#byte portc=7
#byte portd=8
#byte porte=9
void main() {
  char dBuff;
  set_tris_d(0xff);
  set_tris_a(0x00);
  while (1) {
    dBuff=portd;
minemind
PostPosted: Tue Apr 12, 2005 7:29 pm     Reply with quote
You all help me a lot.
TQ.
Emi
minemind
minemind
TQ.
Emi
minemind
