minemind
f877 port D input problem |
Posted: Mon Apr 11, 2005 9:09 pm |
I'm having problem reading from port d. Port d use 10k pullups resistor and port a have led on each pins.
Am i missing something? I cannot read from port d. i'm using ccs ver2.686.
please help me since i've been working around for about quite some time. Below are some of the code.
#fuses HS, NOWDT, PUT, NOBROWNOUT, NOLVP, NOPROTECT
#USE FAST_IO(D)
#USE FAST_IO(E)
#byte portd=8
#byte porte=9
char dBuff;
// i disable all interrupts
// and then. . .
disable_interrupts(GLOBAL);
port_b_pullups(FALSE); // disable pullups
setup_adc_ports(NO_ANALOGS); // disable analogs.
setup_psp(PSP_DISABLED); // disable psp
set_tris_d(0xff);
while (1) {
porta=portd; // send to porta, and this not working
dBuff=portd;
printf("%c", dBuff);
} _________________ minemind |
Sugiman
Posted: Tue Apr 12, 2005 2:29 am |
Did you also set up port A for output somewhere in your code? |
treitmey
try this |
Posted: Tue Apr 12, 2005 8:01 am |
Code: | #include <16F877.h>
#device *=16
#fuses HS,NOWDT,NOLVP,PROTECT,PUT,BROWNOUT
#use rs232(baud=9600,xmit=PIN_C4,INVERT,stream=DEBUG) // STDERR(same as DEBUG)
#use rs232(baud=1200,errors,xmit=PIN_C6,rcv=PIN_C7,parity=e,enable=PIN_C5,bits=8,stream=CIM)
#case
#zero_ram
#define VER_MAJOR 1
#define VER_MINOR 01
#use fast_io(D)
#byte relays=8 //16F877 port D is at 8
#USE FAST_IO(A)
#USE FAST_IO(B)
#USE FAST_IO(C)
#USE FAST_IO(D)
#USE FAST_IO(E)
#byte porta=5
#byte portb=6
#byte portc=7
#byte portd=8
#byte porte=9
char dBuff;
set_tris_d(0xff);
set_tris_a(0x00);
while (1) {
dBuff=portd;
minemind
Thanks |
Posted: Tue Apr 12, 2005 7:29 pm |
You all help me a lot.
TQ.
Emi _________________ minemind |
minemind
Thanks |
TQ.
