0,5s Timer
thiaguetz
0,5s Timer
PostPosted: Sat Mar 12, 2005 7:11 pm     Reply with quote
Hi folks,
I would like to know if exist a way to improve the precision in the following code:
PS.: When my timer reach more than 6 secods, it begin floating some miliseconds.
Thanks!
#include <16f628.h>
#fuses INTRC,NOWDT,PUT,NOMCLR,NOPROTECT,NOCPD,BROWNOUT,NOLVP
#use rs232(baud=19200, parity=N,xmit=PIN_B2,rcv=PIN_B1)
int8 counter;
#define TICK 7,62939453125
#INT_TIMER1
void clock_isr()
    if(--counter==0)
      counter = TICK;
   counter = TICK;
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
   set_timer1(0);
   while (true)
rwyoung
PostPosted: Sat Mar 12, 2005 7:36 pm     Reply with quote
Go search the code archive posts. I believe it was Neutone (sorry if I'm giving credit where credit is not due) that posted some nifty stuff for zero-drift timing.
Rob Young
future
PostPosted: Sun Mar 13, 2005 12:09 am     Reply with quote
#define TICK 7,62939453125 is a float number.
int8 counter; // is an integer
counter = tick; // counter is 7 now
I think you must rethink what you are trying do achieve.
