thiaguetz
0,5s Timer |
Posted: Sat Mar 12, 2005 7:11 pm |
Hi folks,
I would like to know if exist a way to improve the precision in the following code:
PS.: When my timer reach more than 6 secods, it begin floating some miliseconds.
Thanks!
#include <16f628.h>
#fuses INTRC,NOWDT,PUT,NOMCLR,NOPROTECT,NOCPD,BROWNOUT,NOLVP
#use rs232(baud=19200, parity=N,xmit=PIN_B2,rcv=PIN_B1)
int8 counter;
#define TICK 7,62939453125
#INT_TIMER1
void clock_isr()
if(--counter==0)
counter = TICK;
counter = TICK;
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
set_timer1(0);
while (true)
rwyoung
Posted: Sat Mar 12, 2005 7:36 pm |
Go search the code archive posts. I believe it was Neutone (sorry if I'm giving credit where credit is not due) that posted some nifty stuff for zero-drift timing. _________________ Rob Young
future
Posted: Sun Mar 13, 2005 12:09 am |
#define TICK 7,62939453125 is a float number.
int8 counter; // is an integer
counter = tick; // counter is 7 now
I think you must rethink what you are trying do achieve. |
