guest Guest
Array problem |
Posted: Wed Mar 02, 2005 10:48 am |
I have a working code for 16F873A with variable list at bottom. When I changed line with comment out to:
int16 meanval[12];
it can compile without error but it doesn't work even array doesn't use anywhere in code.
Do you have an idea about this problem's reason ?
Thank you
zek
#include "C:\Program Files\PICC\Projects\kd\kd.h"
byte const dissel[3] ={0xEF,0xFB,0xDF};
int32 adctop;
int16 adcval,adcftn,zcr1;
//int16 meanval[12];
int chno=0,flags1=0,flags2=0,gw=0;
int trout=0,trset=0,trval=0,trwait=0,newolc=0;
int disidx=0,keywait=0,flcnt=0,keys=0;
int adc_seq=0,new_seq=255,mper=7,topcnt;
int disbuf[3];
int flmask[3]; |
treitmey
Posted: Wed Mar 02, 2005 12:32 pm |
12*16=192
The compiler trys to put it in 1 contigious area.
http://ww1.microchip.com/downloads/en/DeviceDoc/39582b.pdf
page 18,19,20
I think your limit will be 16+80+16=112 bytes of bank 2 or 3.
Perhaps you can have more than one aray??
It then would not have to be in one area.
Posted: Thu Mar 03, 2005 3:58 am |
Thank you for your support
I looked up to 39582b and I decided to add a #locate command to end of variable list and problem disappeared. (code start to work again with array)
Array located to start of second page.
Thank you again
Zek
int32 adctop;
int16 meanval[12];
int disbuf[3];
int flmask[3];
#locate meanval = 0xA0 |
