		| Author | Message |
		| guest Guest
				| Array problem |
				|  Posted: Wed Mar 02, 2005 10:48 am |   |
				| Hi,
 I have a working code for 16F873A with variable list at bottom. When I changed line with comment out to:
 int16 meanval[12];
 it can compile without error but it doesn't work even array doesn't use  anywhere in code.
 Do you have an idea about this problem's reason ?
 Thank you
 zek
 #include "C:\Program Files\PICC\Projects\kd\kd.h"
 byte const dissel[3] ={0xEF,0xFB,0xDF};
 int32 adctop;
 int16 adcval,adcftn,zcr1;
 //int16 meanval[12];
 int chno=0,flags1=0,flags2=0,gw=0;
 int trout=0,trset=0,trval=0,trwait=0,newolc=0;
 int disidx=0,keywait=0,flcnt=0,keys=0;
 int adc_seq=0,new_seq=255,mper=7,topcnt;
 int disbuf[3];
 int flmask[3];
		| treitmey
				|  Posted: Wed Mar 02, 2005 12:32 pm |   |
				| 12*16=192 The compiler trys to put it in 1 contigious area.
 http://ww1.microchip.com/downloads/en/DeviceDoc/39582b.pdf
 page 18,19,20
 I think your limit will be 16+80+16=112 bytes of bank 2 or 3.
 Perhaps you can have more than one aray??
 It then would not have to be in one area.
		| Guest
				|  Posted: Thu Mar 03, 2005 3:58 am |   |
				| Thank you for your support
 I looked up to 39582b and I decided to add a #locate command to end of variable list and problem disappeared. (code start to work again with array)
 Array located to start of second page.
 Thank you again
 Zek
 int32 adctop;
 int16 meanval[12];
 int disbuf[3];
 int flmask[3];
 #locate meanval = 0xA0
 | You cannot post new topics in this forum You cannot reply to topics in this forum
