Einly
how to set internal resistor |
Posted: Tue Feb 15, 2005 11:21 am |
I use this module to pull up the port b when all bits are input:
#ifdef __PCM__
port_b_pullups(true);
1. what's about pulldown command?
2. If I only want set particular bit pullups, any command to solve it?
e.g. I want pull up PB0, what should I do?
Thanks!
Regards: Einly, _________________ Einly |
rwyoung
Posted: Tue Feb 15, 2005 1:52 pm |
OK, I'll say it: RTFM.
Now that is out of my system, most PIC16Fs (if not all) cannot individually address the weak Port B pull up. A single bit in the OPTION REGister enables or disables ALL the pull ups at the same time.
And as far as I know there is no pull-down built into any PIC I/O port. _________________ Rob Young
rnielsen
Posted: Tue Feb 15, 2005 2:59 pm |
When the pull-up bit is set, if a pin, on portb, is configured as an output the corresponding pull-up is disabled. |
Mark
Posted: Tue Feb 15, 2005 9:30 pm |
I'll second that! Read the manual or actually the datasheet. It tells all.
RTFD  |
