how to set internal resistor
Einly
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger ICQ Number
PostPosted: Tue Feb 15, 2005 11:21 am     Reply with quote
I use this module to pull up the port b when all bits are input:
#ifdef __PCM__
port_b_pullups(true);
1. what's about pulldown command?
2. If I only want set particular bit pullups, any command to solve it?
e.g. I want pull up PB0, what should I do?
Thanks!
Regards: Einly,
Einly
rwyoung
PostPosted: Tue Feb 15, 2005 1:52 pm     Reply with quote
OK, I'll say it: RTFM.
Now that is out of my system, most PIC16Fs (if not all) cannot individually address the weak Port B pull up. A single bit in the OPTION REGister enables or disables ALL the pull ups at the same time.
And as far as I know there is no pull-down built into any PIC I/O port.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
rnielsen
PostPosted: Tue Feb 15, 2005 2:59 pm     Reply with quote
When the pull-up bit is set, if a pin, on portb, is configured as an output the corresponding pull-up is disabled.
Mark
PostPosted: Tue Feb 15, 2005 9:30 pm     Reply with quote
I'll second that! Read the manual or actually the datasheet. It tells all.
RTFD Very Happy
