Large Table
ljbeng
Large Table
PostPosted: Mon Jan 10, 2005 3:55 pm     Reply with quote
In an 18F4620, can I have a single table with 5000 characters?
byte const table1[5000]={"... 5000 CHARACTERS HERE...."};
So far, my test table shows everthing in the table is "\0"
RossJ
PostPosted: Mon Jan 10, 2005 6:19 pm     Reply with quote
I'm using PCWH 3.214 and your code seems to works fine. The .HEX file contains the correct data. However, I didn't check to see if the wrapper code correctly returns the correct byte value. What's in your HEX file? Maybe this is a fault in the retrieval code (returning zero), and not the inserted data. Take a look at the LST file (you will need to edit the device file and comment out the NOLIST directive to see the generated const tables).
