Franz Grueter
IR remote for 110vDC motor speed control |
Posted: Thu Dec 09, 2004 10:50 am |
IR remote for 110v DC motor speed control
Goal: control a 90v winding/115volt DC motor via IR remote control. Peak amps draw: 11. Max torque: 330. HP max .4. Use full wave bridge rectifier to convert AC to DC. Battery powered IR remote is max distance from motor: 9ft. Needed functions: Power on/off ... Motor up/down ... Increase speed/decrease speed. Noise of motor must be kept to a minimum.
Franz, novice |
Re: IR remote for 110vDC motor speed control |
Posted: Thu Dec 09, 2004 11:06 am |
Franz Grueter wrote: | IR remote for 110v DC motor speed control
Franz, novice |
Seriously, safely controlling a motor of this power/voltage, is not really a 'novice' project. Anything over 50v, is potentially a 'dangerous' voltage. Buy an off the shelf voltage controlled motor speed controller, and generate the control voltage for this from a PIC. Look at the Sony IR encoder/decoder chips, which do the hard work of handling an IR stream. In all honesty, the easiest way to do the transmitter, will be to buy a cheap programmable IR remote control, and only build the reciver yourself.
To get an idea of the amount of work involved in a controller of this sort, look at:
http://www.hassockshog.co.uk/motor_controller.htm
which though designed for much higher currents, shows just how much circuitry is involved in such controllers.
