maria Guest
| PIC16F676 header file |
Posted: Tue Dec 07, 2004 9:51 am |
I use the CCS compiler PCM v 3.099.
I am going to start a project using the PIC 16F676, but my compiler hasn't got the header file for it.
Can somebody send it to me,please?
Thanks a lot  |
dyeatman
| The header file wont help.... |
Posted: Tue Dec 07, 2004 1:17 pm |
| The Version 3.099 does not support the 16F676 even if you have the header file so that wont do you any good... |
mirberti Guest
| header file |
Posted: Thu Dec 09, 2004 7:34 am |
this is the header file of 16F676.
by mirko
//////// Standard Header file for the PIC16F676 device ////////////////
#device PIC16F676
#nolist
//////// Program memory: 1024x14 Data RAM: 64 Stack: 8
//////// I/O: 12 Analog Pins: 8
//////// Data EEPROM: 128
//////// C Scratch area: 57 ID Location: 2000
//////// Oscilator Calibration Address: 90
//////// Fuses: LP,XT,HS,EC,INTRC_IO,INTRC,RC_IO,RC,BANDGAPLOW,BANDGAPHIGH
//////// Fuses: PROTECT,NOPROTECT,NOBROWNOUT,BROWNOUT,MCLR,NOMCLR,CPD,NOCPD
//////// Fuses: WDT,NOWDT,PUT,NOPUT
////////////////////////////////////////////////////////////////// I/O
// Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
// PORT_B_PULLUPS(), INPUT(),
// OUTPUT_LOW(), OUTPUT_HIGH(),
// OUTPUT_FLOAT(), OUTPUT_BIT()
// Constants used to identify pins in the above are:
#define PIN_A0 40
#define PIN_A1 41
#define PIN_A2 42
#define PIN_A3 43
#define PIN_A4 44
#define PIN_A5 45
#define PIN_C0 56
#define PIN_C1 57
#define PIN_C2 58
#define PIN_C3 59
#define PIN_C4 60
#define PIN_C5 61
////////////////////////////////////////////////////////////////// Useful defines
#define FALSE 0
#define TRUE 1
#define BYTE int
#define BOOLEAN short int
#define getc getch
#define fgetc getch
#define getchar getch
#define putc putchar
#define fputc putchar
#define fgets gets
#define fputs puts
////////////////////////////////////////////////////////////////// Control
// Control Functions: RESET_CPU(), SLEEP(), RESTART_CAUSE()
// Constants returned from RESTART_CAUSE() are:
#define WDT_FROM_SLEEP 0
#define WDT_TIMEOUT 8
#define MCLR_FROM_SLEEP 16
#define NORMAL_POWER_UP 24
////////////////////////////////////////////////////////////////// Timer 0
// Timer 0 (AKA RTCC)Functions: SETUP_COUNTERS() or SETUP_TIMER0(),
// SET_TIMER0() or SET_RTCC(),
// GET_TIMER0() or GET_RTCC()
// Constants used for SETUP_TIMER0() are:
#define RTCC_INTERNAL 0
#define RTCC_EXT_L_TO_H 32
#define RTCC_EXT_H_TO_L 48
#define RTCC_DIV_1 8
#define RTCC_DIV_2 0
#define RTCC_DIV_4 1
#define RTCC_DIV_8 2
#define RTCC_DIV_16 3
#define RTCC_DIV_32 4
#define RTCC_DIV_64 5
#define RTCC_DIV_128 6
#define RTCC_DIV_256 7
#define RTCC_8_BIT 0
// Constants used for SETUP_COUNTERS() are the above
// constants for the 1st param and the following for
// the 2nd param:
////////////////////////////////////////////////////////////////// WDT
// Watch Dog Timer Functions: SETUP_WDT() or SETUP_COUNTERS() (see above)
// RESTART_WDT()
#define WDT_18MS 8
#define WDT_36MS 9
#define WDT_72MS 10
#define WDT_144MS 11
#define WDT_288MS 12
#define WDT_576MS 13
#define WDT_1152MS 14
#define WDT_2304MS 15
////////////////////////////////////////////////////////////////// Timer 1
// Timer 1 Functions: SETUP_TIMER_1, GET_TIMER1, SET_TIMER1
// Constants used for SETUP_TIMER_1() are:
// (or (via |) together constants from each group)
#define T1_DISABLED 0
#define T1_INTERNAL 0x85
#define T1_EXTERNAL 0x87
#define T1_EXTERNAL_SYNC 0x83
#define T1_CLK_OUT 8
#define T1_DIV_BY_1 0
#define T1_DIV_BY_2 0x10
#define T1_DIV_BY_4 0x20
#define T1_DIV_BY_8 0x30
////////////////////////////////////////////////////////////////// Timer 2
// Timer 2 Functions: SETUP_TIMER_2, GET_TIMER2, SET_TIMER2
// Constants used for SETUP_TIMER_2() are:
#define T2_DISABLED 0
#define T2_DIV_BY_1 4
#define T2_DIV_BY_4 5
#define T2_DIV_BY_16 6
////////////////////////////////////////////////////////////////// COMP
// Comparator Variables: C1OUT, C2OUT
// Constants used in setup_comparators() are:
#define NC_NC_NC_NC 7
#define NC_NC 7
#define A0_A1 2
#define A1_VR_OUT_ON_A2 3
#define A1_VR 4
#define A0_A1_OUT_ON_A2 1
#bit C1OUT = 0x19.6
////////////////////////////////////////////////////////////////// VREF
// Constants used in setup_vref() are:
#define VREF_LOW 0xa0
#define VREF_HIGH 0x80
#define VREF_A2 0x40
////////////////////////////////////////////////////////////////// ADC
// ADC Functions: SETUP_ADC(), SETUP_ADC_PORTS() (aka SETUP_PORT_A),
// SET_ADC_CHANNEL(), READ_ADC()
// Constants used in SETUP_ADC_PORTS() are:
// or together any combination
// of the sANx constants with one
// of the others.
#define sAN0 1 //| A0
#define sAN1 2 //| A1
#define sAN2 4 //| A2
#define sAN3 8 //| A4
#define sAN4 16 //| C0
#define sAN5 32 //| C1
#define sAN6 64 //| C2
#define sAN7 128 //| C3
#define VSS_VDD 0x8000 //x| Range 0-Vdd
#define VREF_VREF 0x9000 //x| Range VrefL-VrefH
#define VRL_VRH 0xA000 //x| Range Vrl-Vrh
#define VSS_VREF 0xB000 //x| Range 0-VrefH
#define VSS_VRH 0xC000 //x| Range 0-Vrl
#define VREF_VDD 0xD000 //x| Range VrefL-Vdd
#define VRL_VDD 0xE000 //x| Range Vrl-Vdd
#define VSS_VRL 0xF000 //x| Range 0-Vrl
// Constants used for SETUP_ADC() are:
#define ADC_OFF 0
#define ADC_CLOCK_DIV_2 1
#define ADC_CLOCK_DIV_4 0x41
#define ADC_CLOCK_DIV_8 0x11
#define ADC_CLOCK_DIV_32 0x21
#define ADC_CLOCK_DIV_16 0x51
#define ADC_CLOCK_DIV_64 0x61
#define ADC_CLOCK_INTERNAL 0x31
// Constants used in READ_ADC() are:
#define ADC_START_AND_READ 7 // This is the default if nothing is specified
#define ADC_START_ONLY 1
#define ADC_READ_ONLY 6
////////////////////////////////////////////////////////////////// INT
// Interrupt Functions: ENABLE_INTERRUPTS(), DISABLE_INTERRUPTS(),
// EXT_INT_EDGE()
// Constants used in EXT_INT_EDGE() are:
#define L_TO_H 0x40
#define H_TO_L 0
// Constants used in ENABLE/DISABLE_INTERRUPTS() are:
#define GLOBAL 0x0BC0
#define INT_RTCC 0x0B20
#define INT_EXT 0x0B10
#define INT_TIMER1 0x8C01
#define INT_TIMER0 0x0B20
#define INT_EEPROM 0x8C80
#define INT_COMP 0x8C08
#define INT_RA 0x0B08
#define INT_RA0 0x010B08
#define INT_RA1 0x020B08
#define INT_RA2 0x040B08
#define INT_RA3 0x080B08
#define INT_RA4 0x100B08
#define INT_RA5 0x200B08
#list
