PIC16F676 header file
maria
PostPosted: Tue Dec 07, 2004 9:51 am     Reply with quote
I use the CCS compiler PCM v 3.099.
I am going to start a project using the PIC 16F676, but my compiler hasn't got the header file for it.
Can somebody send it to me,please?
Thanks a lot Wink
dyeatman
The header file wont help....
PostPosted: Tue Dec 07, 2004 1:17 pm     Reply with quote
The Version 3.099 does not support the 16F676 even if you have the header file so that wont do you any good...
mirberti
header file
PostPosted: Thu Dec 09, 2004 7:34 am     Reply with quote
this is the header file of 16F676.
by mirko
//////// Standard Header file for the PIC16F676 device ////////////////
#device PIC16F676
#nolist
//////// Program memory: 1024x14  Data RAM: 64  Stack: 8
//////// I/O: 12   Analog Pins: 8
//////// Data EEPROM: 128
//////// C Scratch area: 57   ID Location: 2000
//////// Oscilator Calibration Address: 90
//////// Fuses: LP,XT,HS,EC,INTRC_IO,INTRC,RC_IO,RC,BANDGAPLOW,BANDGAPHIGH
//////// Fuses: PROTECT,NOPROTECT,NOBROWNOUT,BROWNOUT,MCLR,NOMCLR,CPD,NOCPD
//////// Fuses: WDT,NOWDT,PUT,NOPUT
////////////////////////////////////////////////////////////////// I/O
// Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
//                         PORT_B_PULLUPS(), INPUT(),
//                         OUTPUT_LOW(), OUTPUT_HIGH(),
//                         OUTPUT_FLOAT(), OUTPUT_BIT()
// Constants used to identify pins in the above are:
#define PIN_A0  40
#define PIN_A1  41
#define PIN_A2  42
#define PIN_A3  43
#define PIN_A4  44
#define PIN_A5  45
#define PIN_C0  56
#define PIN_C1  57
#define PIN_C2  58
#define PIN_C3  59
#define PIN_C4  60
#define PIN_C5  61
////////////////////////////////////////////////////////////////// Useful defines
#define FALSE 0
#define TRUE 1
#define BYTE int
#define BOOLEAN short int
#define getc getch
#define fgetc getch
#define getchar getch
#define putc putchar
#define fputc putchar
#define fgets gets
#define fputs puts
////////////////////////////////////////////////////////////////// Control
// Control Functions:  RESET_CPU(), SLEEP(), RESTART_CAUSE()
// Constants returned from RESTART_CAUSE() are:
#define WDT_FROM_SLEEP  0
#define WDT_TIMEOUT     8
#define MCLR_FROM_SLEEP 16
#define NORMAL_POWER_UP 24
////////////////////////////////////////////////////////////////// Timer 0
// Timer 0 (AKA RTCC)Functions: SETUP_COUNTERS() or SETUP_TIMER0(),
//                              SET_TIMER0() or SET_RTCC(),
//                              GET_TIMER0() or GET_RTCC()
// Constants used for SETUP_TIMER0() are:
#define RTCC_INTERNAL   0
#define RTCC_EXT_L_TO_H 32
#define RTCC_EXT_H_TO_L 48
#define RTCC_DIV_1      8
#define RTCC_DIV_2      0
#define RTCC_DIV_4      1
#define RTCC_DIV_8      2
#define RTCC_DIV_16     3
#define RTCC_DIV_32     4
#define RTCC_DIV_64     5
#define RTCC_DIV_128    6
#define RTCC_DIV_256    7
#define RTCC_8_BIT      0
// Constants used for SETUP_COUNTERS() are the above
// constants for the 1st param and the following for
// the 2nd param:
////////////////////////////////////////////////////////////////// WDT
// Watch Dog Timer Functions: SETUP_WDT() or SETUP_COUNTERS() (see above)
//                            RESTART_WDT()
#define WDT_18MS        8
#define WDT_36MS        9
#define WDT_72MS       10
#define WDT_144MS      11
#define WDT_288MS      12
#define WDT_576MS      13
#define WDT_1152MS     14
#define WDT_2304MS     15
////////////////////////////////////////////////////////////////// Timer 1
// Timer 1 Functions: SETUP_TIMER_1, GET_TIMER1, SET_TIMER1
// Constants used for SETUP_TIMER_1() are:
//      (or (via |) together constants from each group)
#define T1_DISABLED         0
#define T1_INTERNAL         0x85
#define T1_EXTERNAL         0x87
#define T1_EXTERNAL_SYNC    0x83
#define T1_CLK_OUT          8
#define T1_DIV_BY_1         0
#define T1_DIV_BY_2         0x10
#define T1_DIV_BY_4         0x20
#define T1_DIV_BY_8         0x30
////////////////////////////////////////////////////////////////// Timer 2
// Timer 2 Functions: SETUP_TIMER_2, GET_TIMER2, SET_TIMER2
// Constants used for SETUP_TIMER_2() are:
#define T2_DISABLED         0
#define T2_DIV_BY_1         4
#define T2_DIV_BY_4         5
#define T2_DIV_BY_16        6
////////////////////////////////////////////////////////////////// COMP
// Comparator Variables: C1OUT, C2OUT
// Constants used in setup_comparators() are:
#define NC_NC_NC_NC  7
#define NC_NC  7
#define A0_A1  2
#define A1_VR_OUT_ON_A2  3
#define A1_VR  4
#define A0_A1_OUT_ON_A2  1
#bit C1OUT = 0x19.6
////////////////////////////////////////////////////////////////// VREF
// Constants used in setup_vref() are:
#define VREF_LOW  0xa0
#define VREF_HIGH 0x80
#define VREF_A2   0x40
////////////////////////////////////////////////////////////////// ADC
// ADC Functions: SETUP_ADC(), SETUP_ADC_PORTS() (aka SETUP_PORT_A),
//                SET_ADC_CHANNEL(), READ_ADC()
// Constants used in SETUP_ADC_PORTS() are:
//     or together any combination
//     of the sANx constants with one
//     of the others.
#define sAN0                   1         //| A0
#define sAN1                   2         //| A1
#define sAN2                   4         //| A2
#define sAN3                   8         //| A4
#define sAN4                  16         //| C0
#define sAN5                  32         //| C1
#define sAN6                  64         //| C2
#define sAN7                  128        //| C3
#define VSS_VDD               0x8000          //x| Range 0-Vdd
#define VREF_VREF             0x9000          //x| Range VrefL-VrefH
#define VRL_VRH               0xA000          //x| Range Vrl-Vrh
#define VSS_VREF              0xB000          //x| Range 0-VrefH
#define VSS_VRH               0xC000          //x| Range 0-Vrl
#define VREF_VDD              0xD000          //x| Range VrefL-Vdd
#define VRL_VDD               0xE000          //x| Range Vrl-Vdd
#define VSS_VRL               0xF000          //x| Range 0-Vrl
// Constants used for SETUP_ADC() are:
#define ADC_OFF                0
#define ADC_CLOCK_DIV_2        1
#define ADC_CLOCK_DIV_4     0x41
#define ADC_CLOCK_DIV_8     0x11
#define ADC_CLOCK_DIV_32    0x21
#define ADC_CLOCK_DIV_16    0x51
#define ADC_CLOCK_DIV_64    0x61
#define ADC_CLOCK_INTERNAL  0x31
// Constants used in READ_ADC() are:
#define ADC_START_AND_READ     7   // This is the default if nothing is specified
#define ADC_START_ONLY         1
#define ADC_READ_ONLY          6
////////////////////////////////////////////////////////////////// INT
// Interrupt Functions: ENABLE_INTERRUPTS(), DISABLE_INTERRUPTS(),
//                      EXT_INT_EDGE()
// Constants used in EXT_INT_EDGE() are:
#define L_TO_H              0x40
#define H_TO_L                 0
// Constants used in ENABLE/DISABLE_INTERRUPTS() are:
#define GLOBAL                    0x0BC0
#define INT_RTCC                  0x0B20
#define INT_EXT                   0x0B10
#define INT_TIMER1                0x8C01
#define INT_TIMER0                0x0B20
#define INT_EEPROM                0x8C80
#define INT_COMP                  0x8C08
#define INT_RA                    0x0B08
#define INT_RA0                   0x010B08
#define INT_RA1                   0x020B08
#define INT_RA2                   0x040B08
#define INT_RA3                   0x080B08
#define INT_RA4                   0x100B08
#define INT_RA5                   0x200B08
#list
