has someone used a Sony Ericsson GT47/GT48? please help
runtime
PostPosted: Thu Apr 14, 2005 3:49 pm     Reply with quote
Do I need a MAX232 to interface the GT48 to my PC?
Can I use just TX, RX and GND signals to talk to the GT48?
Thank you in advance
Peter
PostPosted: Thu Apr 14, 2005 4:58 pm     Reply with quote
I don't know, but there are a lot of documents for the GT47 available
at this webpage:
http://www.com2000.it/italiano/download/download.htm
PostPosted: Fri Apr 15, 2005 3:55 am     Reply with quote
Download the Tecnical Description manual from the above mentioned website. Page 16 describes the electrical voltages on the RS232 pins. all are +/-13V or +/-25V, so no MAX232 is required for interfacing to the PC.
Fabricio
PostPosted: Fri Apr 15, 2005 7:44 am     Reply with quote
I have worked with the GM47/48. I donīt know which differs has with the GT47/48. But the GM 47/48 needs max232 to connect itself to the PC
PostPosted: Fri Apr 15, 2005 8:08 am     Reply with quote
GM47 is a Module without enclosure for embedded applications.
GT47 is a Terminal with enclosure and all electonics like power supply and MAX232 included.
