Posted: Fri Apr 15, 2005 3:55 am
Download the Tecnical Description manual from the above mentioned website. Page 16 describes the electrical voltages on the RS232 pins. all are +/-13V or +/-25V, so no MAX232 is required for interfacing to the PC.
Fabricio
Posted: Fri Apr 15, 2005 7:44 am
I have worked with the GM47/48. I donīt know which differs has with the GT47/48. But the GM 47/48 needs max232 to connect itself to the PC
Posted: Fri Apr 15, 2005 8:08 am
GM47 is a Module without enclosure for embedded applications.
GT47 is a Terminal with enclosure and all electonics like power supply and MAX232 included.
