		| Author | Message |
		| hansknec
				| Bargraph Code for Hitachi type LCD |
				|  Posted: Thu Sep 30, 2004 1:02 pm |   |
				| Does anybody have a function written to generate a horizontal bargraph on an LCD (with Hitachi HD44780 controller)?  I have recently started using PIC C and also use PIC Basic Pro.  In PBP I have an "include" file that writes straight bars to the CGRAM area of the display.  Later if I wish to make a variable display as a bargraph I simply call a subroutine that automatically writes the bars and fill spaces to form the bar.  In the code I have, each character space can contain 0 to 3 vertical lines, therefore a 16 character width display can have a bar that displays from 0 to 48 individual lines.  I think I'll be able to convert the Basic to C, but a few of the LCD calls appear to be quite different in C.  The basic bargraph code was written by Scott Edwards and released to the PIC basic users.  I suppose I could post it if someone thinks they can properly modify it for C.  I use 16X2 line parallel (4bit mode) lcd's exclusively, so please don't respond with serial LCD info unless it is somehow directly applicable.
 -John
		| Will Reeve
				|  Posted: Thu Sep 30, 2004 1:33 pm |   |
				| I have done just what you suggest; the code was used on a VFD using a LCD ‘compatible’ controller. The VFD has the desired custom characters already in its character map. I see that the normal HD44780U LCD character map doesn’t have them so you will need to make your own custom characters.
 You need 5, the first one has a single vertical line, the second 2, and so on until you have a completely solid character.
 Basically the code works out how many solid characters to display, and then what the last character should be. Looking at it now it generates a 10 character bar graph in a string called bar as I was also giving a description of the variable graphed on the same line. You will have to modify the math to give you 16 characters!
 Works very well in practice.
  	  | Code: |  	  | /******************************************************************************* * void generatebar(int8 percent)
 * Purpose:  This function generates the text line for the bar graph indicator
 void generate_bar(int8 percent) {
 int8 solid,last;
 int8 i = 0;
 solid = percent / 10; // number of solid characters to display
 last = percent - (solid * 10); // work out the last character
 last /= 2;
 if (solid) {
 for (i=0;i<solid;i++)
 bar[i] = 0x14;
 } // if (solid)
 if (last) {
 last--;
 bar[i] = 0x10 + last; // select last character
 i++;
 bar[i] = '\0';
 } // generate_bar(int8 percent)
		| hansknec
				|  Posted: Thu Sep 30, 2004 2:00 pm |   |
				| Yes, this portion of the code looks straight forward, but it is the actual LCD writing that worries me.  When writing to the CGRAM, it looks like I need to have the address and desired value to that address.  When wanting the LCD to print a character, either from it's stock list of characters or the CGRAM, I simply enter the address of the character to print.  With PBP it seemed easy, but I'm not sure when and where I should be using lcd_putc( char c) or lcd_send_byte(0,1) or the other multitude of commands available to me in C.  I'm only in my 3rd day of actually writing to an LCD, so please forgive my ignorance.   I know this can't be too hard.  I need to tell it where to write and what to write.  More code please if you have it.  |  |
		| Will Reeve
				|  Posted: Thu Sep 30, 2004 2:37 pm |   |
				| Hi, I’ve dug some code out of an old project. This function will set up you user defined characters:
  	  | Code: |  	  | /***************************************************************************** * init_user_chars
 * Purpose:   Set pointer in LCD memory to CGRAM and load first 8 bytes with
 *         user defined characters. Reset pointer to line 1, position 1
 void init_user_chars(void) {
 // User defined characters 5 x 7 but remember the cursor on 8
 int8 i;
 // char 0x00 nice degree sign
 const char user_char[49] = {0x06, 0x09, 0x09, 0x06, 0x00, 0x00, 0x00, 0x00,
 // char 0x01 nice tick sign
 0x00, 0x00, 0x00, 0x01, 0x02, 0x14, 0x08, 0x00,
 // char 0x02 approx sign
 0x00, 0x00, 0x08, 0x1D, 0x17, 0x02, 0x00, 0x00,
 // char 0x03 stir forward
 0x00, 0x10, 0x08, 0x04, 0x02, 0x01, 0x00, 0x00,
 // char 0x04 stir vertical
 0x00, 0x04, 0x04, 0x04, 0x04, 0x04, 0x00, 0x00,
 // char 0x05 stir backward
 0x00, 0x01, 0x02, 0x04, 0x08, 0x10, 0x00, 0x00};
 lcd_send_byte(0,64); // Sets ram address
 for (i=0; i<49;i++)
 lcd_send_byte(1,user_char[i]);
 lcd_gotoxy(1,1); // Resets address to top line / position 1
 } // init_user_chars
 This is the function I always use to write out data to the LCD.
  	  | Code: |  	  | /******************************************************************************* * send_to_lcd(int8 location,char *s1)
 * Purpose:   Write the supplied strings to the top or bottom line of the LCD
 *         16x2 LCD screen depending on location
 void send_to_lcd(int8 location,char *s1) {
 int i, iLen;
 iLen=strlen(s1);
 // Write to top line
 lcd_gotoxy(1,location);
 // Protect against coding errors
 if (iLen>16)
 iLen=16;
 for(i=0;i<iLen;i++) {
 // Built in auto substitution of Numerical zero with O
 if(s1[i]==48) s1[i]=0x4F;
 lcd_putc(s1[i]);
 } // for
 for (i=iLen; i<16; i++) lcd_putc(' ');
 } // send_to_lcd
  	  | Code: |  	  | void lcd_putc(char c) { lcd_send_byte(1,c);
 } // lcd_putc
 This is a typical line of code which uses the send_to_lcd function.
  	  | Code: |  	  | sprintf(line1,"Low Batteries"); send_to_lcd(1,line1);
 To send the user characters just send 0x00 to 0x05 for instance.
 Hope these help.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
