Bargraph Code for Hitachi type LCD
hansknec
PostPosted: Thu Sep 30, 2004 1:02 pm     Reply with quote
Does anybody have a function written to generate a horizontal bargraph on an LCD (with Hitachi HD44780 controller)? I have recently started using PIC C and also use PIC Basic Pro. In PBP I have an "include" file that writes straight bars to the CGRAM area of the display. Later if I wish to make a variable display as a bargraph I simply call a subroutine that automatically writes the bars and fill spaces to form the bar. In the code I have, each character space can contain 0 to 3 vertical lines, therefore a 16 character width display can have a bar that displays from 0 to 48 individual lines. I think I'll be able to convert the Basic to C, but a few of the LCD calls appear to be quite different in C. The basic bargraph code was written by Scott Edwards and released to the PIC basic users. I suppose I could post it if someone thinks they can properly modify it for C. I use 16X2 line parallel (4bit mode) lcd's exclusively, so please don't respond with serial LCD info unless it is somehow directly applicable.
-John
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Thu Sep 30, 2004 1:33 pm     Reply with quote
I have done just what you suggest; the code was used on a VFD using a LCD ‘compatible’ controller. The VFD has the desired custom characters already in its character map. I see that the normal HD44780U LCD character map doesn’t have them so you will need to make your own custom characters.
You need 5, the first one has a single vertical line, the second 2, and so on until you have a completely solid character.
Basically the code works out how many solid characters to display, and then what the last character should be. Looking at it now it generates a 10 character bar graph in a string called bar as I was also giving a description of the variable graphed on the same line. You will have to modify the math to give you 16 characters!
Works very well in practice.
* void generatebar(int8 percent)
* Purpose:  This function generates the text line for the bar graph indicator
void generate_bar(int8 percent) {
   int8 solid,last;
   int8 i = 0;
   solid = percent / 10; // number of solid characters to display
   last = percent - (solid * 10); // work out the last character
   last /= 2;
   if (solid) {
      for (i=0;i<solid;i++)
        bar[i] = 0x14;
   } // if (solid)
   if (last) {
      last--;
      bar[i] = 0x10 + last; // select last character
      i++;
   bar[i] = '\0';
} // generate_bar(int8 percent)
hansknec
PostPosted: Thu Sep 30, 2004 2:00 pm     Reply with quote
Yes, this portion of the code looks straight forward, but it is the actual LCD writing that worries me. When writing to the CGRAM, it looks like I need to have the address and desired value to that address. When wanting the LCD to print a character, either from it's stock list of characters or the CGRAM, I simply enter the address of the character to print. With PBP it seemed easy, but I'm not sure when and where I should be using lcd_putc( char c) or lcd_send_byte(0,1) or the other multitude of commands available to me in C. I'm only in my 3rd day of actually writing to an LCD, so please forgive my ignorance. I know this can't be too hard. I need to tell it where to write and what to write. More code please if you have it. Wink
Will Reeve
PostPosted: Thu Sep 30, 2004 2:37 pm     Reply with quote
Hi, I’ve dug some code out of an old project. This function will set up you user defined characters:
* init_user_chars
* Purpose:   Set pointer in LCD memory to CGRAM and load first 8 bytes with
*         user defined characters. Reset pointer to line 1, position 1
void init_user_chars(void) {
   // User defined characters 5 x 7 but remember the cursor on 8
   int8 i;
   // char 0x00 nice degree sign
    const char user_char[49] = {0x06, 0x09, 0x09, 0x06, 0x00, 0x00, 0x00, 0x00,
   // char 0x01 nice tick sign
                          0x00, 0x00, 0x00, 0x01, 0x02, 0x14, 0x08, 0x00,
   // char 0x02 approx sign
                          0x00, 0x00, 0x08, 0x1D, 0x17, 0x02, 0x00, 0x00,
   // char 0x03 stir forward
                         0x00, 0x10, 0x08, 0x04, 0x02, 0x01, 0x00, 0x00,
   // char 0x04 stir vertical
                         0x00, 0x04, 0x04, 0x04, 0x04, 0x04, 0x00, 0x00,
   // char 0x05 stir backward
                         0x00, 0x01, 0x02, 0x04, 0x08, 0x10, 0x00, 0x00};
   lcd_send_byte(0,64); // Sets ram address
   for (i=0; i<49;i++)
      lcd_send_byte(1,user_char[i]);
   lcd_gotoxy(1,1); // Resets address to top line / position 1
} // init_user_chars
This is the function I always use to write out data to the LCD.
* send_to_lcd(int8 location,char *s1)
* Purpose:   Write the supplied strings to the top or bottom line of the LCD
*         16x2 LCD screen depending on location
void send_to_lcd(int8 location,char *s1) {
int i, iLen;
   iLen=strlen(s1);
   // Write to top line
   lcd_gotoxy(1,location);
   // Protect against coding errors
   if (iLen>16)
      iLen=16;
   for(i=0;i<iLen;i++) {
      // Built in auto substitution of Numerical zero with O
      if(s1[i]==48) s1[i]=0x4F;
      lcd_putc(s1[i]);
   } // for
   for (i=iLen; i<16; i++) lcd_putc(' ');
} // send_to_lcd
void lcd_putc(char c) {
lcd_send_byte(1,c);
} // lcd_putc
This is a typical line of code which uses the send_to_lcd function.
sprintf(line1,"Low Batteries");
send_to_lcd(1,line1);
To send the user characters just send 0x00 to 0x05 for instance.
Hope these help.
