OT: fast data storage device
Sigma
PostPosted: Wed Sep 29, 2004 7:33 pm     Reply with quote
hi, all,
For time critical application, what do you use for data storage? I used to use FRAM from ramtron. Although performance not bad, i want to have more choices. Would you recommend?
Thanks.
Sigma
valemike
Battery backed-up NVRAM
PostPosted: Thu Sep 30, 2004 8:55 am     Reply with quote
If you're concerned about the the time it takes to save to EEPROM, and want something as fast as the RAM in the PIC, then you should use battery-backed up NVRAM. It is an SGS-thomson chip that was embedded in a powerpc-based single board computer board that I used. 8 lines are connected to it. Just specify the address, read/write, and write to that location. No waiting.
