I made a new project in MPLAB6.0 using PCM version 3.212 and using a source file from an earlier project that built normally in that project. When I build in the new project I get the following:
Clean: Deleating intermediary and output files
Clean: Done
Executing:"C\program files\picc\Ccsx.exe"multi.c
No errors
Skipping link step. Not all sources built successfully
Build failed time and date
There is only one source file "multi.c" and I still get a hex file that works as expected despite the message. It's been awhile since my last new project so I'm not sure what versions I used to make the projects that build normally. Thanks in advance for any insight
Thanks for the information. I changed to the numbered Pic reference and now all is well. Sorry I didn't read far enough through the messages to see this without posting. Thanks again
