Wierd message after building in MPLAB6.0
Rod P.
PostPosted: Sun Oct 03, 2004 10:49 am     Reply with quote
Hello to all,
I made a new project in MPLAB6.0 using PCM version 3.212 and using a source file from an earlier project that built normally in that project. When I build in the new project I get the following:
Clean: Deleating intermediary and output files
Clean: Done
Executing:"C\program files\picc\Ccsx.exe"multi.c
No errors
Skipping link step. Not all sources built successfully
Build failed time and date
There is only one source file "multi.c" and I still get a hex file that works as expected despite the message. It's been awhile since my last new project so I'm not sure what versions I used to make the projects that build normally. Thanks in advance for any insight
Rod
Rod p
Sorry it's Mplab 6.60 not 6.0
PostPosted: Sun Oct 03, 2004 11:06 am     Reply with quote
I made an error and ment to say version 6.60.
PostPosted: Sun Oct 03, 2004 11:11 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=20580&highlight=skipping+link+step
Rod P.
Thanks to PCM Programmer and Ttelmah!
PostPosted: Sun Oct 03, 2004 2:31 pm     Reply with quote
Thanks for the information. I changed to the numbered Pic reference and now all is well. Sorry I didn't read far enough through the messages to see this without posting. Thanks again
Rod Very Happy
