tomi7
Problem with LCD display |
Posted: Wed Sep 15, 2004 1:25 pm |
I have problem with LCD display. I have use functions from orginal lcd.c and set PortB for LCD interface. This program doesn't work, led diode turns on once, but i hapens only sometimes. When I remove LCD function, led diode is flashing.
What is wrong ?
prg.h
#include <18F248.h>
#device adc=8
#fuses NOWDT,WDT128,XT, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, PUT, NOCPD, STVREN, NODEBUG, LVP, NOWRT, NOWRTD, NOWRTB, NOCPB, NOWRTC, NOEBTR, NOEBTRB
prg.c
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
lcd_init();
while(1){
lcd_gotoxy(1,1);
lcd_putc("Hello Word ...\n");
output_high(PIN_C3);
output_low(PIN_C3);
Arif Guest
Posted: Thu Sep 16, 2004 12:59 am |
i tried your code and you have to select NOLVP from fuses. Then it will work... Because when lvp selected pinb4 used for LVP function and b4 can not be used for general i/o. |
rnielsen
Posted: Thu Sep 16, 2004 11:33 am |
I think the NOLVP setting has bitten quite a few people, myself included. |
tomi7
Posted: Thu Sep 16, 2004 3:20 pm |
Yes, NOLVP helps, uffff
Thanks You very much. |
