Problem with LCD display
tomi7
PostPosted: Wed Sep 15, 2004 1:25 pm     Reply with quote
I have problem with LCD display. I have use functions from orginal lcd.c and set PortB for LCD interface. This program doesn't work, led diode turns on once, but i hapens only sometimes. When I remove LCD function, led diode is flashing.
What is wrong ?
prg.h
#include <18F248.h>
#device adc=8
#fuses NOWDT,WDT128,XT, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, PUT, NOCPD, STVREN, NODEBUG, LVP, NOWRT, NOWRTD, NOWRTB, NOCPB, NOWRTC, NOEBTR, NOEBTRB
prg.c
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
lcd_init();
while(1){
lcd_gotoxy(1,1);
lcd_putc("Hello Word ...\n");
output_high(PIN_C3);
output_low(PIN_C3);
Arif
PostPosted: Thu Sep 16, 2004 12:59 am     Reply with quote
i tried your code and you have to select NOLVP from fuses. Then it will work... Because when lvp selected pinb4 used for LVP function and b4 can not be used for general i/o.
rnielsen
PostPosted: Thu Sep 16, 2004 11:33 am     Reply with quote
I think the NOLVP setting has bitten quite a few people, myself included.
tomi7
PostPosted: Thu Sep 16, 2004 3:20 pm     Reply with quote
Yes, NOLVP helps, uffff Very Happy
Thanks You very much.
