itsjustmatt Guest
Error: "PCM" not installed on this pc... |
Posted: Wed Feb 19, 2003 11:26 pm |
I'm using Win Xp, CCS PCM V3.030. It works fine under MPLAB 5.6. Using the patch and MPLAB 6.10 I get "Error: "PCM" not installed on this pc..." when trying to compile, however the program window pops up and disappears. I got the same thing using the TechTools IDE. I've also used "+fm" to ensure PCM is selected". I've uninstalled/reinstalled the all software with no change. Any clue?
Matt
Original Post ID: 11904 |
chris_1982 Guest
Re: Error: "PCM" not installed on this pc... |
Posted: Thu Feb 20, 2003 3:00 am |
I had this problem yesterday I just reinstalled the CCS program without uninstalling it and it worked after that
chris
:=I'm using Win Xp, CCS PCM V3.030. It works fine under MPLAB 5.6. Using the patch and MPLAB 6.10 I get "Error: "PCM" not installed on this pc..." when trying to compile, however the program window pops up and disappears. I got the same thing using the TechTools IDE. I've also used "+fm" to ensure PCM is selected". I've uninstalled/reinstalled the all software with no change. Any clue?
:=Matt
Original Post ID: 11908 |
FrustratedPicker Guest
Re: I'm haveing the same F'in error!!! |
Posted: Thu Feb 20, 2003 4:13 pm |
:=Matt
I'm using win98, MPLAB 6.12, and PCW, IDE V3.2,PCM 3.032, I also have V3.092 but can't seem to make it work even on its own, so just been sticking with the 3.032 version..
I installed the mplab6 install and reinstalled everything a couple times never seems to work. Strangely if I run CSSC.exe directly it creates NONAME.err which says the same thing?
Original Post ID: 11932 |
Freddie L Guest
Posted: Sat Feb 22, 2003 2:12 pm |
I had this problem. It was because I did not have the correct PIC Device Selected. Be sure that you have the correct PIC Chip selected under the Menu Configure|Select Device.
-cheers!
:=Matt
Original Post ID: 12017 |
