Error: "PCM" not installed on this pc...
itsjustmatt
PostPosted: Wed Feb 19, 2003 11:26 pm     Reply with quote
I'm using Win Xp, CCS PCM V3.030. It works fine under MPLAB 5.6. Using the patch and MPLAB 6.10 I get "Error: "PCM" not installed on this pc..." when trying to compile, however the program window pops up and disappears. I got the same thing using the TechTools IDE. I've also used "+fm" to ensure PCM is selected". I've uninstalled/reinstalled the all software with no change. Any clue?
Matt
___________________________
Original Post ID: 11904
chris_1982
Re: Error: "PCM" not installed on this pc...
PostPosted: Thu Feb 20, 2003 3:00 am     Reply with quote
I had this problem yesterday I just reinstalled the CCS program without uninstalling it and it worked after that
chris
:=I'm using Win Xp, CCS PCM V3.030. It works fine under MPLAB 5.6. Using the patch and MPLAB 6.10 I get "Error: "PCM" not installed on this pc..." when trying to compile, however the program window pops up and disappears. I got the same thing using the TechTools IDE. I've also used "+fm" to ensure PCM is selected". I've uninstalled/reinstalled the all software with no change. Any clue?
:=Matt
Original Post ID: 11908
FrustratedPicker
Re: I'm haveing the same F'in error!!!
PostPosted: Thu Feb 20, 2003 4:13 pm     Reply with quote
:=Matt
I'm using win98, MPLAB 6.12, and PCW, IDE V3.2,PCM 3.032, I also have V3.092 but can't seem to make it work even on its own, so just been sticking with the 3.032 version..
I installed the mplab6 install and reinstalled everything a couple times never seems to work. Strangely if I run CSSC.exe directly it creates NONAME.err which says the same thing?
Original Post ID: 11932
Freddie L
PostPosted: Sat Feb 22, 2003 2:12 pm     Reply with quote
I had this problem. It was because I did not have the correct PIC Device Selected. Be sure that you have the correct PIC Chip selected under the Menu Configure|Select Device.
-cheers!
:=Matt
Original Post ID: 12017
