dbrown
| PIC16F873A and int_rda |
Posted: Sat Jul 24, 2004 2:32 pm |
I have been trying to detect an input on the RS232 port of the pic, and turn on an led. I use Visual basic to send the string "*R" to the port. The signal is at pin a5(recieve pin) but no change in led state. I have tried using #int_rda with no success, however when I use #int_ext that does work with an input on pin B0. I have posted both the working #int_ext code, and the non-working #int_rda code. Any suggestions would be appreciated.
Working code below:
| Code: | #include <16F873A.h>
#use delay (clock=4000000)
#fuses XT,NOWDT,NOPROTECT,nolvp
#USE RS232(BAUD=9600, XMIT=PIN_a4, RCV=PIN_a5,errors)
INT T;
#INT_EXT
ISR(){
OUTPUT_HIGH(PIN_B5);
main(){
enable_interrupts(INT_EXT);
OUTPUT_LOW(PIN_B5);
Non-working code below:
| Code: | ]#use delay (clock=4000000)
INT T;
#INT_RDA
ISR(){
main(){
enable_interrupts(INT_RDA);
OUTPUT_LOW(PIN_B5);
Dave B |
| Re: PIC16F873A and int_rda |
Posted: Sat Jul 24, 2004 2:52 pm |
| dbrown wrote: | I have been trying to detect an input on the RS232 port of the pic, and turn on an led. I use Visual basic to send the string "*R" to the port. The signal is at pin a5(recieve pin) but no change in led state. I have tried using #int_rda with no success, however when I use #int_ext that does work with an input on pin B0. I have posted both the working #int_ext code, and the non-working #int_rda code. Any suggestions would be appreciated.
Working code below:
INT T;
#INT_EXT
ISR(){
main(){
OUTPUT_LOW(PIN_B5);
INT T;
#INT_RDA
ISR(){
main(){
OUTPUT_LOW(PIN_B5);
Dave B |
The problem is that you are letting the code run 'off the end'. CCS, puts a sleep instruction after the last byte of your program. Once asleep, the receive interrupt cannot wake the chip (the only events that can wake the chip, are MCLR, a watchdog timeout, or a RB interrupt.
Change the code to:
INT T;
#INT_RDA
ISR(){
main(){
OUTPUT_LOW(PIN_B5);
//This stops the code running off the end.
while (TRUE);
dbrown
Posted: Sat Jul 24, 2004 3:43 pm |
| I just tried the adding the line while(1), but it still will not cooperate. |
Posted: Sun Jul 25, 2004 2:12 am |
| dbrown wrote: | | I just tried the adding the line while(1), but it still will not cooperate. |
The obvious remaining 'major mistake', is that you are not connecting to the UART, so the RDA interrupt will nevr occur...
The hardware UART on a 16F873, is on pins RC6(TX), and RC7(RX). These are the pins you have to connect to to use the UART...
A4, and A5, will not work.
Mark
Posted: Sun Jul 25, 2004 9:03 am |
| You will also need to read the value to prevent getting an overflow condition. |
Posted: Sun Jul 25, 2004 11:51 am |
Thank-you for the responses, they are much appreciated.
Just to clairify my understanding on int_rda. If I redefine the TX and RX pins from the hardware location ie: move RX from C7 to A5 the interrupt will not be re-mapped to match the new location? Therefore the only way that int_rda will function is if the #use statement conforms to the hardware location of the RX and TX pins?
Thanks again
Dave B |
Posted: Sun Jul 25, 2004 12:24 pm |
| Quote: | | Just to clairify my understanding on int_rda. If I redefine the TX and RX pins from the hardware location ie: move RX from C7 to A5 the interrupt will not be re-mapped to match the new location? Therefore the only way that int_rda will function is if the #use statement conforms to the hardware location of the RX and TX pins? |
This is correct. Only the hardware based UART is capable of generating an interrupt and this hardware UART is connected to C7 and can not be changed to iother pins. |
