PIC16F873A and int_rda
dbrown
PostPosted: Sat Jul 24, 2004 2:32 pm     Reply with quote
I have been trying to detect an input on the RS232 port of the pic, and turn on an led. I use Visual basic to send the string "*R" to the port. The signal is at pin a5(recieve pin) but no change in led state. I have tried using #int_rda with no success, however when I use #int_ext that does work with an input on pin B0. I have posted both the working #int_ext code, and the non-working #int_rda code. Any suggestions would be appreciated.
Working code below:
#include <16F873A.h>
#use delay (clock=4000000)
#fuses XT,NOWDT,NOPROTECT,nolvp
#USE RS232(BAUD=9600, XMIT=PIN_a4, RCV=PIN_a5,errors)
INT T;
#INT_EXT
ISR(){
OUTPUT_HIGH(PIN_B5);
main(){
enable_interrupts(INT_EXT);
OUTPUT_LOW(PIN_B5);
Non-working code below:
]#use delay (clock=4000000)
INT T;
#INT_RDA
ISR(){
main(){
enable_interrupts(INT_RDA);
OUTPUT_LOW(PIN_B5);
Dave B
Re: PIC16F873A and int_rda
PostPosted: Sat Jul 24, 2004 2:52 pm     Reply with quote
Working code below:
INT T;
#INT_EXT
ISR(){
main(){
OUTPUT_LOW(PIN_B5);
INT T;
#INT_RDA
ISR(){
main(){
OUTPUT_LOW(PIN_B5);
Dave B
The problem is that you are letting the code run 'off the end'. CCS, puts a sleep instruction after the last byte of your program. Once asleep, the receive interrupt cannot wake the chip (the only events that can wake the chip, are MCLR, a watchdog timeout, or a RB interrupt.
Change the code to:
INT T;
#INT_RDA
ISR(){
main(){
OUTPUT_LOW(PIN_B5);
//This stops the code running off the end.
while (TRUE);
dbrown
PostPosted: Sat Jul 24, 2004 3:43 pm     Reply with quote
I just tried the adding the line while(1), but it still will not cooperate.
PostPosted: Sun Jul 25, 2004 2:12 am     Reply with quote
The obvious remaining 'major mistake', is that you are not connecting to the UART, so the RDA interrupt will nevr occur...
The hardware UART on a 16F873, is on pins RC6(TX), and RC7(RX). These are the pins you have to connect to to use the UART...
A4, and A5, will not work.
Mark
PostPosted: Sun Jul 25, 2004 9:03 am     Reply with quote
You will also need to read the value to prevent getting an overflow condition.
PostPosted: Sun Jul 25, 2004 11:51 am     Reply with quote
Thank-you for the responses, they are much appreciated.
Just to clairify my understanding on int_rda. If I redefine the TX and RX pins from the hardware location ie: move RX from C7 to A5 the interrupt will not be re-mapped to match the new location? Therefore the only way that int_rda will function is if the #use statement conforms to the hardware location of the RX and TX pins?
Thanks again
Dave B
PostPosted: Sun Jul 25, 2004 12:24 pm     Reply with quote
This is correct. Only the hardware based UART is capable of generating an interrupt and this hardware UART is connected to C7 and can not be changed to iother pins.
