problematic array
problematic array
PostPosted: Fri Jun 25, 2004 4:11 pm     Reply with quote
I have a question on how to increment an array.
First the important stuff:
PCM 3.148
12F629
I have an array which I initialise thus:
// all variables are global \\
//numbers
#define   ZERO            0x7E
#define   ONE            0x0C
#define   TWO            0xB6
#define   THREE            0x9E
#define   FOUR            0xCC
#define   FIVE            0xDA
#define   SIX            0xFA
#define   SEVEN            0x0E
#define   EIGHT            0xFE
#define   NINE            0xDE
//LCD display
int   digits[10]   =   {ZERO,ONE,TWO,THREE,FOUR,FIVE,SIX,SEVEN,EIGHT,NINE};
int   digit_counter    =   0;   //used to keep track of displayed digit
int   bit_counter   =   0;   //used to keep track of bits within each digit
It is used in the main loop
while (TRUE)
   //cycle through digits 0 -> 9
      for   (;   digit_counter <=9;   digit_counter++)
         //increment array
            digits[digit_counter];
         //set clock low
         output_low(S_CLK);
         //clock bits out from the array element
         for   (;   bit_counter <=7; bit_counter++)
            output_bit(S_DATA,shift_right(digits,1,0));
            //clock bit out
            output_high(S_CLK);
            delay_cycles(1);
            output_low(S_CLK);
         //reset bit_counter
         if   (8 == bit_counter)
            bit_counter = 0;
What I am trying to achieve, is to clock each element of the array serially out through a port pin. It will work the first time as 'digit_counter' is initialised at 0, and I can see the code running as I expect it to via the simulator. However I cannot get the next element of the array to load. I was hoping to use 'bit_counter' to index the elements of the array?
The code compiles and when I run it through the simulator it steps over the line.... digits[digit_counter]; which I hoped was going to increment the array?
Looking at the .lst there is no code shown for this line?
Its getting late and I've probably done something silly - its just that I cant see it. All suggestions gratefully received.
adrian
PostPosted: Fri Jun 25, 2004 4:14 pm     Reply with quote
Err I don't know what happened here?
Sorry for the duplication
