problematic array |
Posted: Fri Jun 25, 2004 4:11 pm |
I have a question on how to increment an array.
First the important stuff:
PCM 3.148
12F629
I have an array which I initialise thus:
// all variables are global \\
//numbers
#define ZERO 0x7E
#define ONE 0x0C
#define TWO 0xB6
#define THREE 0x9E
#define FOUR 0xCC
#define FIVE 0xDA
#define SIX 0xFA
#define SEVEN 0x0E
#define EIGHT 0xFE
#define NINE 0xDE
//LCD display
int digits[10] = {ZERO,ONE,TWO,THREE,FOUR,FIVE,SIX,SEVEN,EIGHT,NINE};
int digit_counter = 0; //used to keep track of displayed digit
int bit_counter = 0; //used to keep track of bits within each digit
It is used in the main loop
while (TRUE)
//cycle through digits 0 -> 9
for (; digit_counter <=9; digit_counter++)
//increment array
digits[digit_counter];
//set clock low
output_low(S_CLK);
//clock bits out from the array element
for (; bit_counter <=7; bit_counter++)
output_bit(S_DATA,shift_right(digits,1,0));
//clock bit out
output_high(S_CLK);
delay_cycles(1);
output_low(S_CLK);
//reset bit_counter
if (8 == bit_counter)
bit_counter = 0;
What I am trying to achieve, is to clock each element of the array serially out through a port pin. It will work the first time as 'digit_counter' is initialised at 0, and I can see the code running as I expect it to via the simulator. However I cannot get the next element of the array to load. I was hoping to use 'bit_counter' to index the elements of the array?
The code compiles and when I run it through the simulator it steps over the line.... digits[digit_counter]; which I hoped was going to increment the array?
Looking at the .lst there is no code shown for this line?
Its getting late and I've probably done something silly - its just that I cant see it. All suggestions gratefully received. |
adrian
Posted: Fri Jun 25, 2004 4:14 pm |
Err I don't know what happened here?
Sorry for the duplication |
