Gizz
Joined: 15 Jun 2004 Posts: 21 Location: Nottingham UK
Simple C char* question, old C hacks please help! |
Posted: Wed Jun 16, 2004 7:01 am |
Hi
Well, I'm up and running with the CCS compiler, and its nicer (so far) than the Hi-Tech one. But I seem to be forgetting my C (I'm a C# hack these days...).
I have the following:
void SendMessage(char* msg)
printf(msg);
putc(10);
putch(13);
Calling this like so:
SendMessage("A test message");
results in garbage being sent down the RS232.
Calling like so:
char temp[100];
strcpy(temp, "A test message");
SendMessage(temp);
works just fine.
Anyone know why the first instance fails?
Its an 877A using the PICDEM2 and ICD2
TIA! |
Re: Simple C char* question, old C hacks please help! |
Posted: Wed Jun 16, 2004 8:07 am |
Gizz wrote: | Hi
printf(msg);
putc(10);
putch(13);
Calling like so:
char temp[100];
SendMessage(temp);
works just fine.
TIA! |
Probably one of the most common "FAQ's" for the CCS compiler. It does not support pointers to constant strings (this is in the manual)...
The second version, copies the constant string from ROM to RAM, and this can then be sent normally.
A search through the forum, looking for comments like 'pointers to ROM', will find some of the thousands of posts about this.
SteveS
Posted: Wed Jun 16, 2004 9:49 am |
Oh, I see it's another one of your rude RTFM replies, Ttelmah!
(big time just kidding!!!! - I couldn't resist)
- SteveS |
Gizz
Posted: Wed Jun 16, 2004 9:55 am |
OK, thanks, if I had a FM to FR I would! LOL! |
Try this... |
Posted: Wed Jun 16, 2004 10:39 am |
As it's just a constant message, you could use
puts( " this is a message" );
Hans W |
Posted: Wed Jun 16, 2004 8:26 pm |
printf(msg);
putc(10);
putch(13);
Sounds like a job for the C preprocessor. A macro will behave like an inline function, and the compiler will generate the appropriate code for the context. |
Posted: Thu Jun 17, 2004 10:57 am |
Gizz wrote: | OK, thanks, if I had a FM to FR I would! LOL! |
The 'FM', is on the web...
Best Wishes ![Smile](images/smiles/icon_smile.gif) |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Thu Jun 17, 2004 5:46 pm |
Here it is: FM ![Very Happy](images/smiles/icon_biggrin.gif) |
