Simple C char* question, old C hacks please help!
Gizz
PostPosted: Wed Jun 16, 2004 7:01 am     Reply with quote
Hi
Well, I'm up and running with the CCS compiler, and its nicer (so far) than the Hi-Tech one. But I seem to be forgetting my C (I'm a C# hack these days...).
I have the following:
void SendMessage(char* msg)
printf(msg);
putc(10);
putch(13);
Calling this like so:
SendMessage("A test message");
results in garbage being sent down the RS232.
Calling like so:
char temp[100];
strcpy(temp, "A test message");
SendMessage(temp);
works just fine.
Anyone know why the first instance fails?
Its an 877A using the PICDEM2 and ICD2
TIA!
Re: Simple C char* question, old C hacks please help!
PostPosted: Wed Jun 16, 2004 8:07 am     Reply with quote
Gizz wrote:
Hi
printf(msg);
putc(10);
putch(13);
Calling like so:
char temp[100];
SendMessage(temp);
works just fine.
TIA!
Probably one of the most common "FAQ's" for the CCS compiler. It does not support pointers to constant strings (this is in the manual)...
The second version, copies the constant string from ROM to RAM, and this can then be sent normally.
A search through the forum, looking for comments like 'pointers to ROM', will find some of the thousands of posts about this.
SteveS
PostPosted: Wed Jun 16, 2004 9:49 am     Reply with quote
Oh, I see it's another one of your rude RTFM replies, Ttelmah!
(big time just kidding!!!! - I couldn't resist)
- SteveS
Gizz
PostPosted: Wed Jun 16, 2004 9:55 am     Reply with quote
OK, thanks, if I had a FM to FR I would! LOL!
Try this...
PostPosted: Wed Jun 16, 2004 10:39 am     Reply with quote
As it's just a constant message, you could use
puts( " this is a message" );
Hans W
PostPosted: Wed Jun 16, 2004 8:26 pm     Reply with quote
printf(msg);
putc(10);
putch(13);
Sounds like a job for the C preprocessor. A macro will behave like an inline function, and the compiler will generate the appropriate code for the context.
PostPosted: Thu Jun 17, 2004 10:57 am     Reply with quote
The 'FM', is on the web...
Best Wishes Smile
Haplo
PostPosted: Thu Jun 17, 2004 5:46 pm     Reply with quote
Here it is: FM Very Happy
