frustrated Beginner Guest
16F876 and Bootlader |
Posted: Fri Apr 23, 2004 3:45 am |
I have trouble with the bootloader for the 16F876.
I can't get them to work.
I try to use the www.microchipc.com bootloader, but it seems that the downloader programm isn't able to find the pic.
I use the 20Mhz 19200baud hex-file but i can't get them to work.
Has anyone an idea?
I#m a PIC-Beginner and
I'm frustrated....
Regards |
Posted: Fri Apr 23, 2004 11:42 am |
You will have to provide us with more information before we are able to help you.
I assume you are using the PIC16F876? And you are sure it is running at 20MHz?
What tools did you use to program the initial bootloader in the PIC?
Is your PIC running on a standard development board we might know of, or is it your own development?
How is the PIC connected to your computer.
What exactly is working, and what part not?
etc, etc, etc. |
frustrated beginner Guest
Posted: Mon Apr 26, 2004 11:10 pm |
at first, i got it to work !
i use a millennium board with a pic 16f876
at 20 Mhz and 19200bps.
I only got it to work at 4 Mhz and 9600bps.
and now i'm trying to make it run with 20 Mhz and 19200bps..
regards
beginner |
lucky
Joined: 12 Sep 2003 Posts: 46 Location: South Coast - England
18452 Bootloader |
Posted: Tue Apr 27, 2004 3:48 am |
Me too. I use this bootloader for the 18F452 & found that it would only work 100% of the time at 2400.
At 9600 it would work the first time but never a second time. I think it is to do with the Xon Xoff because @ 2400 it is so slow it works just as well without Xon Xoff.
If you solve this please let us know. _________________ Lucky
www.mpic3.com - MPIC3 player project, Forum, Downloads, Online Shop |
i solved it |
Posted: Thu Apr 29, 2004 11:23 pm |
i got the bootloader running at 20Mhz and 19200bps.
I used the asm file and changed it to 20Mhz and 19200bps.
I compiled the file and burned it into the pic.
And it works great
It is so fast.
Mfg
Beginner |
