Posted: Tue Mar 30, 2004 11:51 am |
I did a test compile, and got the same result.
You'll have to email CCS support about it.
With luck, they will send you a new Devices.dat
file to correct the problem.
It did create code for the write_program_eeprom()
function. I didn't check it to see if the code was
correct, and I don't have a chip to test it on.
But if it works, it will let you continue your project.
(Or, you could write your own routine). |
