Problem with "write_program_memory()" at 18F6680
UKH
PostPosted: Tue Mar 30, 2004 3:15 am     Reply with quote
Hallo together,
I have some problems with the function write_program_memory().
A program which is compiled for PIC18F458 works correctly. The
same program compiled for PIC18F6680 generates no code
for write_program_memory(). It looks like that the compiler
"think" that the device has no FLASH-ROM Question
Has someone observed something like this too ?
Kind regards
U.K.
PostPosted: Tue Mar 30, 2004 11:51 am     Reply with quote
I did a test compile, and got the same result.
You'll have to email CCS support about it.
With luck, they will send you a new Devices.dat
file to correct the problem.
It did create code for the write_program_eeprom()
function. I didn't check it to see if the code was
correct, and I don't have a chip to test it on.
But if it works, it will let you continue your project.
(Or, you could write your own routine).
