serial command to an HCR330 reader
David
PostPosted: Wed Aug 10, 2005 9:04 pm     Reply with quote
Hello
My name's David and I begin to use CCS compiler with MPLAB.
I have a problem to send a serial command to a HCR330 smartcard reader.
The reader specifications are :
- 9600 baud rate
- 8 bits data length
- parity none
- 1 stop bit
I want to send the command "<ESC>E" and I made this little program ->
#if defined(__PCM__)
#include <16F877.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 1
#elif defined(__PCB__)
#include <16c56.h>
#use rs232(baud=9600, xmit=PIN_A3, rcv=PIN_A2) // Jumpers: 11 to 17, 12 to 18
#elif defined(__PCH__)
#include <18F452.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12
int a, b;
a = 0x1b
b = 0x45
printf(a, b)
I tried to set a and b in Dec like this a = 27 and b = 69 but It doesn't working too and I don't know why.
Have you an idea about that and can you help me ?
Thank you
Best regards
David
asmallri
PostPosted: Wed Aug 10, 2005 9:23 pm     Reply with quote
printf("\x1bE");
Regards, Andrew
PostPosted: Wed Aug 10, 2005 11:13 pm     Reply with quote
Also you can do it this way:
main()
int8 a;
int8 b;
a = 0x1b;
b = 0x45;
putc(a);
putc(b);
or this way:
main()
putc(0x1b);
putc(0x45);
or this way:
#define ESCAPE_CHAR  0x1b
main()
putc(ESCAPE_CHAR);
putc('E');    //  The 'E' character must be in single quotes
