| David
				| serial command to an HCR330 reader |
				|  Posted: Wed Aug 10, 2005 9:04 pm |   |
				| Hello
 My name's David and I begin to use CCS compiler with MPLAB.
 I have a problem to send a serial command to a HCR330 smartcard reader.
 The reader specifications are :
 - 9600 baud rate
 - 8 bits data length
 - parity none
 - 1 stop bit
 I want to send the command "<ESC>E" and I made this little program ->
 #if defined(__PCM__)
 #include <16F877.h>
 #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 1
 #elif defined(__PCB__)
 #include <16c56.h>
 #use rs232(baud=9600, xmit=PIN_A3, rcv=PIN_A2)  // Jumpers: 11 to 17, 12 to 18
 #elif defined(__PCH__)
 #include <18F452.h>
 #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
 int a, b;
 a = 0x1b
 b = 0x45
 printf(a, b)
 I tried to set a and b in Dec like this a = 27 and b = 69 but It doesn't working too and I don't know why.
 Have you an idea about that and can you help me ?
 Thank you
 Best regards
 David
