snoo Guest
icd-u40 installation help |
Posted: Tue Feb 24, 2004 7:22 pm |
Hi
I am trying to install the ICD u40 on windows XP.
Could someone tell me , what is the right way to install it.
My way:
-I put the ICD on usb un my PC, when it detect a new hardware
i install the ICD-U Drivers for windows (29 august 2003).
-When the drivers are installed,
I install the icu-U Software (Feb 12 2004).
After that, i try to execute ICD.exe but
i do not have the target window.
I know that my icd-u is working well, because it
is working in 1 of my 2 pc.
Now i try to install it on my laptop, is not working.
Could you help me.
Steph |
ICDU |
Posted: Tue Feb 24, 2004 10:03 pm |
I just installed the ICDU on my XP laptop using the ICDU Kit instruction card with no problems. (Slightly different order than you did it)
When you say "target window" I assume you mean the debug window? I had to click the debug button to get this window to appear then changed the interface mode on the Debug Configure tab from ICDS to ICDU and it worked perfectly after that.... |
snoo Guest
ICD U compiler version |
Posted: Wed Feb 25, 2004 11:10 am |
HI Dyeatman
I had read some, message about compiler version,
Could you tell me what kind of version do you have? |
Posted: Wed Feb 25, 2004 11:22 am |
I am using PCW 3.184 (I backed down from 3.185). and the latest drivers from the CCS web site.
dave |
snoo Guest
Posted: Wed Feb 25, 2004 11:37 am |
Hi dyeatman
Sorry, i lost the card is coming with the icd.
Could you tell me what is the difference about my installation
and your installation procedure?
Could you tell me the number of the last firmware are you using?
I will try it. |
Posted: Wed Feb 25, 2004 11:50 am |
1. Created a directory on my hard drive and copied the all the software (ICDU and drivers) to it.
2. Installed the ICDU software from the new directory.
3. Powered up the ICDU with the prototype board attached
4. Connected the USB cable to the computer
5. When prompted for the drivers I pointed the driver install to the driver directory I created.
6. Rebooted the system
The ICDU had firmware 1.19 and I upgraded to 1.20 version after the install was completed. I used this same procedure on two WIN98 systems and an XP system and both worked perfectly afterward. |
snoo Guest
Posted: Thu Feb 26, 2004 6:40 am |
Hi Dyeatman
I followed your procedure, the installation in the device manager
told me that the icu u40 installation is correct.
I tried to execute icd.exe, i saw the start connection page.
i try to connect, but it is still not working.
I install the PCWH 3.168, and now, icd.exe is working!
Could you tell me why?
But, if i try to install PCWH3.184, is not working.
It is wrote firmware problem.
If i need to upgrade firmware to use PCWH 3.184,
How can i do it
Snoo |
ICDU |
Posted: Thu Feb 26, 2004 8:24 am |
1. Make sure you ahve the latest firmware file unzipped and ready in the CCS directory on your hard drive.
2. Open the Debug screen and select the Config tab
3. Click the right hand button on the tab that looks like a pair of crossed tools.
4. The Tools window will appear. From that window you can update fimware and run diagnostics on the ICDU.
Dave |
snoo Guest
firmware |
Posted: Thu Feb 26, 2004 11:43 am |
Could you confirm that the firmware
is include in the pcwh software?
or where can i find it? |
ICDU Firmware |
Posted: Thu Feb 26, 2004 12:13 pm |
When you install the latest version of ICDU software the file:
icdfirmware-01-20.fw
is installed in the PICC directory, therefore 1.20 is the latest version and is included in the ICDU software.
ICDU is found here:
http://www.ccsinfo.com/download.shtml |
snoo Guest
firmware |
Posted: Fri Feb 27, 2004 6:17 pm |
Hi dyeatman
It seems my problem coming from firmware version,
in icd.exe folder 1.20 and the one get on my icd 1.15.
Why, i said 1.15 because when i start the pcwh 3.168
it is write 1.15 in firmware. In my laptop 1.20 firmware.
Could you explain me why?
or do you understand it something.
I expect, i do not understand firmware version.
on icd.
Steph |
