		| Author | Message |
		| tmach
				| A/D conversion time accuracy |
				|  Posted: Sun Jan 25, 2004 11:01 am |   |
				| Hello! I am using the A/D functionality in 16F874A. I am trying to exactly determine the A/D conversion time by using timer 0 reading. Please advice me if my calculations are right. I am using 20MHz oscillator, which means timer increments at the rate of .2 us (1/(20000000*4)). My code follows,
 #include <16f874A.h>
 #device ADC=10;
 #fuses HS,NOWDT,NOPROTECT
 #use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7)
 #int_ad
 toggle_incr()
 toggle = 1;
 #int_timer0
 timer0_isr()
 timer_overflow++;
 int8 timer_overflow = 0; //number of times the counter has overflown in   between A/D conversion
 main()
 int8 seconds = 0;
 setup_adc_ports(ALL_ANALOG);
 setup_adc( ADC_CLOCK_DIV_32 );
 set_timer0(0);
 setup_counters(RTCC_INTERNAL,RTCC_DIV_1); //count 256
 enable_interrupts(INT_AD);
 while(TRUE) // Main program loop
 set_timer0(0);
 timer_overflow = 0;
 seconds = get_timer0(); //get initial count
 A2D(); //calls A/D routine. Not included in code
 seconds -=get_timer0(); //get final count
 printf("%02u %02u \n",seconds, timer_overflow);
 seconds gives the counter reading and  timer_overflow gives number of timer overflows. So the total A/D coversion is:
 (timer_overflow * 256  + seconds) * 0.2 us + 50 * .2 us
 The 50 is included  to account for the interrupt routine time lapse.
		| Ttelmah Guest
				| Re: A/D conversion time accuracy |
				|  Posted: Sun Jan 25, 2004 3:54 pm |   |
				|  	  | tmach wrote: |  	  | Hello! I am using the A/D functionality in 16F874A. I am trying to exactly determine the A/D conversion time by using timer 0 reading. Please advice me if my calculations are right. I am using 20MHz oscillator, which means timer increments at the rate of .2 us (1/(20000000*4)). My code follows,
 #device ADC=10;
 #int_ad
 toggle_incr()
 toggle = 1;
 #int_timer0
 timer0_isr()
 timer_overflow++;
 main()
 int8 seconds = 0;
 set_timer0(0);
 set_timer0(0);
 timer_overflow = 0;
 Don't waste so much effort. Have no 'carry' counter, set the timer to 0, trigger the conversion, and read the counter when it finishes. Total clocks=counter*4.
 This will include the overhead of reading the bytes, from the AD, and the counter.
 The ADC conversion time, is Tad*12, plus the time taken to trigger the conversion, and the time taken to read it. Typically perhaps 15 instructions. Tad, is 1/625000 second (20000000/32). A total of about 450 clocks, which will give a count of about 112. Hence a 'carry' is not needed.
 Best Wshes
 | You cannot post new topics in this forum You cannot reply to topics in this forum
