tmach
A/D conversion time accuracy |
Posted: Sun Jan 25, 2004 11:01 am |
Hello!
I am using the A/D functionality in 16F874A. I am trying to exactly determine the A/D conversion time by using timer 0 reading. Please advice me if my calculations are right. I am using 20MHz oscillator, which means timer increments at the rate of .2 us (1/(20000000*4)). My code follows,
#include <16f874A.h>
#device ADC=10;
#fuses HS,NOWDT,NOPROTECT
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7)
#int_ad
toggle_incr()
toggle = 1;
#int_timer0
timer0_isr()
timer_overflow++;
int8 timer_overflow = 0; //number of times the counter has overflown in between A/D conversion
main()
int8 seconds = 0;
setup_adc_ports(ALL_ANALOG);
setup_adc( ADC_CLOCK_DIV_32 );
set_timer0(0);
setup_counters(RTCC_INTERNAL,RTCC_DIV_1); //count 256
enable_interrupts(INT_AD);
while(TRUE) // Main program loop
set_timer0(0);
timer_overflow = 0;
seconds = get_timer0(); //get initial count
A2D(); //calls A/D routine. Not included in code
seconds -=get_timer0(); //get final count
printf("%02u %02u \n",seconds, timer_overflow);
seconds gives the counter reading and timer_overflow gives number of timer overflows. So the total A/D coversion is:
(timer_overflow * 256 + seconds) * 0.2 us + 50 * .2 us
The 50 is included to account for the interrupt routine time lapse. |
Re: A/D conversion time accuracy |
Posted: Sun Jan 25, 2004 3:54 pm |
tmach wrote: | Hello!
#device ADC=10;
#int_ad
toggle_incr()
toggle = 1;
#int_timer0
timer0_isr()
timer_overflow++;
main()
int8 seconds = 0;
set_timer0(0);
set_timer0(0);
timer_overflow = 0;
Don't waste so much effort. Have no 'carry' counter, set the timer to 0, trigger the conversion, and read the counter when it finishes. Total clocks=counter*4.
This will include the overhead of reading the bytes, from the AD, and the counter.
The ADC conversion time, is Tad*12, plus the time taken to trigger the conversion, and the time taken to read it. Typically perhaps 15 instructions. Tad, is 1/625000 second (20000000/32). A total of about 450 clocks, which will give a count of about 112. Hence a 'carry' is not needed.
Best Wshes |
