is an appnote from Atmel how to use Dataflash with their AVR controllers.
You should be able to get what you need out of this.
Best regards
dvsoft
Posted: Sat Dec 20, 2003 2:11 am
Hello
I use the following code with a AT45DB321B I hope that it will help you
Alain
// SPI I/O
#ifndef __SPI_IO__
#USE fast_io(c)
#define SPI_SO PIN_A5 // SPI Out pin
#define SPI_SI PIN_A4 // SPI In pin
#define SPI_SCK PIN_E0 // SPI Out Clock pin
#define SPI_TRIS_A 0x30 // Tris on port A
#define SPI_TRIS_E 0x00 // Tris on port E
#endif
// Function :write_SPI
// Version :0.1
// Author :Alain
// Usage :write_SPI(Data)
// Arguments:BYTE Data Data to write
// Return :void
// Modify :void
// Shift one Byte out on the falling edge of the clock.
void write_SPI(BYTE Shift)
BYTE BitCnt = 8;
//--- Shifts out
do {
//--- Clock low
output_low(SPI_SCK);
//--- Bit = 1
if(Shift & 0x80)
output_high(SPI_SO);
//--- Bit = 0
output_low(SPI_SO);
Shift <<= 1;
//--- Clock high
output_high(SPI_SCK);
} while (--BitCnt);
// Function :read_SPI
// Version :0.1
// Author :Alain
// Usage :Data = read_SPI(void)
// Arguments:void
// Return :BYTE Data -> Read result
// Modify :void
// Read one Byte in data on the rising edge of the clock.
BYTE read_SPI()
BYTE Shift,BitCnt = 8;
//--- Shift in
do {
//--- Clock Low, high
Shift <<= 1;
//--- Bit = 0
if(!input(SPI_SI))
Shift &= ~1;
//--- Bit = 1
Shift |= 1;
} while (--BitCnt);
return (Shift);
