driver for at45db041
Rob Sterling
PostPosted: Sat Dec 20, 2003 12:29 am     Reply with quote
Has anybody used the at45db041 and written a driver for it. I am trying to use the at45db041 but am not having much luck with the data storage.
Any help will be appriciated.
rob Very Happy
Hans
PostPosted: Sat Dec 20, 2003 2:05 am     Reply with quote
might not be exactly what you want but this:
http://www.atmel.com/dyn/resources/prod_documents/doc1456.pdf
is an appnote from Atmel how to use Dataflash with their AVR controllers.
You should be able to get what you need out of this.
Best regards
dvsoft
PostPosted: Sat Dec 20, 2003 2:11 am     Reply with quote
Hello
I use the following code with a AT45DB321B I hope that it will help you
Alain
// SPI I/O
#ifndef __SPI_IO__
#USE fast_io(c)
#define SPI_SO PIN_A5 // SPI Out pin
#define SPI_SI PIN_A4 // SPI In pin
#define SPI_SCK PIN_E0 // SPI Out Clock pin
#define SPI_TRIS_A 0x30 // Tris on port A
#define SPI_TRIS_E 0x00 // Tris on port E
// Function :write_SPI
// Version :0.1
// Author :Alain
// Usage :write_SPI(Data)
// Arguments:BYTE Data Data to write
// Return :void
// Modify :void
// Shift one Byte out on the falling edge of the clock.
void write_SPI(BYTE Shift)
BYTE BitCnt = 8;
//--- Shifts out
do {
//--- Clock low
output_low(SPI_SCK);
//--- Bit = 1
if(Shift & 0x80)
output_high(SPI_SO);
//--- Bit = 0
output_low(SPI_SO);
Shift <<= 1;
//--- Clock high
output_high(SPI_SCK);
} while (--BitCnt);
// Function :read_SPI
// Version :0.1
// Author :Alain
// Usage :Data = read_SPI(void)
// Arguments:void
// Return :BYTE Data -> Read result
// Modify :void
// Read one Byte in data on the rising edge of the clock.
BYTE read_SPI()
BYTE Shift,BitCnt = 8;
//--- Shift in
do {
//--- Clock Low, high
Shift <<= 1;
//--- Bit = 0
if(!input(SPI_SI))
Shift &= ~1;
//--- Bit = 1
Shift |= 1;
} while (--BitCnt);
return (Shift);
// DataFlash I/O
#USE fast_io(b)
#define DTF_CS PIN_E1
// DataFlash Macro
#define DTF_SELECT() output_low(DTF_CS)
#define DTF_UNSELECT() output_high(DTF_CS)
#define DTF_WAIT_LOOP 3
// DataFlash value
#define DTF_FIRST_PAGE 257
#define DTF_BUFFER_SIZE 512
#define DTF_SECTOR_SIZE 528
#define DTF_MAX_PAGE 8192
#define DTF_PREFIXE_SIZE (DTF_SECTOR_SIZE-DTF_BUFFER_SIZE)
#define DTF_PREFIXE_OFFSET 0x02
#define DTF_VERSION 0xC0
#define DTF_SIGNATURE 0x0A
// DataFlash command
#define DTF_WRITE_BUFFER_1 0x84
#define DTF_WRITE_BUFFER_2 0x87
#define DTF_READ_BUFFER_1 0x54
#define DTF_READ_BUFFER_2 0x56
#define DTF_MM_TO_BUFFER_1 0x53
#define DTF_MM_TO_BUFFER_2 0x55
// DataFlash Prog mode
#ifdef __BUILT_IN_ERASE__
#define DTF_BUFFER_1_TO_MM 0x83
#define DTF_BUFFER_2_TO_MM 0x86
#else
#define DTF_BUFFER_1_TO_MM 0x88
#define DTF_BUFFER_2_TO_MM 0x89
// DataFlash data
int16 DTF_ByteCounter;
int16 DTF_PageCounter;
BOOLEAN DTF_BUFFER_1_ENABLED;
// DataFlash prototype
BOOLEAN DTF_WaitReady(void);
BYTE DTF_ReadStatus(void);
BYTE DTF_Init(void);
BYTE DTF_ErasePage(int16 PageNum);
BOOLEAN DTF_WritePrefix(BOOLEAN Clear);
BOOLEAN DTF_ReadPrefix(void);
BOOLEAN DTF_RamToPage(int16 PageNum);
BOOLEAN DTF_PageToRam(int16 PageNum);
BYTE Status,iLoop;
//--- Selected
DTF_SELECT();
//--- Read Status Command
write_SPI(0x57);
//--- Max wait loop
iLoop = DTF_WAIT_LOOP;
do {
Status = read_SPI();
}while(!(Status & 0x80) && --iLoop);
//--- Unselected
DTF_UNSELECT();
if (!iLoop)
return (FALSE);
return (TRUE);
BYTE DTF_ReadStatus()
BYTE Status;
//--- Select
DTF_SELECT();
//--- Command (8bits)
write_SPI(0x57);
//--- Ready Result
//--- Unselect
DTF_UNSELECT();
return (Status);
BYTE DTF_Init(void)
BYTE Status;
//--- Status
DTF_ReadStatus();
DTF_ReadStatus();
//--- Maybe no flash device connected ???
if(Status == 0xFF )
return (2);
//--- Control Density Code for AT45DB321B
if (Status & 0x80) {
//--- Get density value
if (((Status >> 3) & 0x7) != 0x06)
return (1);
}// End IF
return 0;
//--- Wait DTF_Ready
DTF_WaitReady ();
//--- Check valide page address
if ((PageNum >= 0 && PageNum < DTF_MAX_PAGE)) {
//--- Page*4
PageNum <<= 2;
//--- Select
DTF_SELECT();
//--- command (32bits)
write_SPI(0x81);
//--- 7 high address bits
write_SPI(*((BYTE*)&PageNum + 1));
//--- 6 low address bits
write_SPI((BYTE)PageNum);
//--- don't care 8 bits
write_SPI(0x00);
//--- Unselect
DTF_UNSELECT();
DTF_WaitReady ();
//--- Ok
return (0);
}// ENd IF
return (2);
BYTE DTF_EraseAllPage()
BYTE Status;
int16 MaxPage = DTF_MAX_PAGE;
//--- Delete loop
do {
Status = DTF_ErasePage(MaxPage);
} while ((--MaxPage >= DTF_FIRST_PAGE) && !Status);
//--- DataFlash buffer1 is Active Buffer
DTF_BUFFER_1_ENABLED = TRUE;
//--- Reset byte counter
DTF_ByteCounter = 0;
//--- Reset Page Counter
DTF_PageCounter = 0;
return Status;
int16 StartAddress = DTF_PREFIXE_OFFSET;
if (!DTF_WaitReady ())
return (FALSE);
//--- Write the value into the active RAM buffer
DTF_SELECT();
//--- Active buffer 1
if (DTF_BUFFER_1_ENABLED)
write_SPI(DTF_WRITE_BUFFER_1);
//--- Active Buffer 2
write_SPI(DTF_WRITE_BUFFER_2);
//--- don't cares 8 bits
write_SPI(0x00);
//--- don't cares 8 bits + first 2 bits of address
write_SPI(*((BYTE*)&StartAddress +1));
//--- Low address bits
write_SPI((BYTE)StartAddress);
if (!Clear) {
//--- Version
write_SPI(DTF_VERSION);
//--- Sync
write_SPI(DTF_SIGNATURE);
}// End IF
else {
//--- Clear prefixe
write_SPI(0x00);
write_SPI(0x00);
}// End Else
//--- Unselect
DTF_UNSELECT();
//--- Success
return (TRUE);
BYTE Version,SyncValue;
BOOLEAN RetValue = TRUE;
//--- Prefix byte address
//--- Write prefixe to RAM buffer
DTF_SELECT();
return (FALSE);
write_SPI(DTF_READ_BUFFER_1);
write_SPI(DTF_READ_BUFFER_2);
write_SPI(0x00);
write_SPI(0x00);
//--- Version Value
Version = read_SPI();
//--- Syncho value
SyncValue = read_SPI();
if (SyncValue != DTF_SIGNATURE || Version != DTF_VERSION)
RetValue = FALSE;
//--- Unselect
DTF_UNSELECT();
return (RetValue);
if (!DTF_WaitReady())
return FALSE;
//--- Active buffer to main memory page
PageNum <<= 2;
//--- Select
DTF_SELECT();
if (DTF_BUFFER_1_ENABLED) {
//--- Write Buffer 1 to Memory Page with built-in Erase
write_SPI(DTF_BUFFER_1_TO_MM);
DTF_BUFFER_1_ENABLED = FALSE;
}// End IF
else {
//--- Write Buffer 2 to Memory Page with built-in Erase
write_SPI(DTF_BUFFER_2_TO_MM);
//--- Active Buffer 1
}// End ELse
write_SPI(0x83);
write_SPI(0x00);
//--- Unselect
DTF_UNSELECT();
return (TRUE);
return (FALSE);
//--- Load memory page
PageNum <<= 2;
//--- Select
DTF_SELECT();
//--- Main Memory Page To Buffer 1
write_SPI(DTF_MM_TO_BUFFER_1);
//--- Main Memory Page To Buffer 2
write_SPI(DTF_MM_TO_BUFFER_2);
write_SPI(0x00);
//--- Unselect
DTF_UNSELECT();
return (TRUE);
